Amana Carbide Tipped Straight Plunge Router Cutters 1/2" Shank
- AMAX harder carbide
- Two flute design
- Ideal for cutting wood, MDF and plywood
Amana 8 Piece General Purpose CNC Router Cutter Set AMS174 1/4" ShankSpecial Price £169.87 £141.56 was £208.18 £173.48 Save £38.31 £31.92
Amana 4 Piece CNC Simulated MDF Shaker Door SetSpecial Price £100.76 £83.97 was £123.48 £102.90 Save £22.72 £18.93
Amana 3 Piece Starter Engraving SetSpecial Price £215.57 £179.64 was £264.18 £220.15 Save £48.61 £40.51
Amana 8 Piece General Purpose CNC Router Cutter Set AMS134 1/4" ShankSpecial Price £140.90 £117.42 was £172.68 £143.90 Save £31.78 £26.48
Amana 8 Piece General Purpose CNC Router Cutter Set AMS177K 1/4" ShankSpecial Price £142.45 £118.71 was £174.58 £145.48 Save £32.13 £26.77
Amana Master CNC Router Cutter Set with Display & 57 CuttersSpecial Price £1,673.60 £1,394.67 was £2,050.98 £1,709.15 Save £377.38 £314.48
Amana Carbide Insert Spoilboard Router Cutter 1/2" ShankSpecial Price £157.80 £131.50 was £193.38 £161.15 Save £35.58 £29.65
Amana Carbide Tipped Spoilboard Router Cutter 1/4" ShankSpecial Price £22.26 £18.55 was £27.28 £22.73 Save £5.02 £4.18
These router bits feature a two-flute design for a very fine finish. The two flutes balance the cutting bit, which reduces any vibration that would degrade the finish. They make two cuts per revolution which produces a smooth surface, but must be at a slightly reduced feed rate.
This range of bits from Amana are manufactured in their AMAX Extended Life carbide, which offers a number of benefits:
Increased life by 200% even when working with abrasive materials
Superior geometric design
Improved resistance to wear
Super clean cuts
These bits are excellent for cutting the following materials:
Wood
MDF
Plywood
Suitable for use with CNC routers, router tables and handheld routers.
