Earn extra with DOUBLE Points on all purchases!
Bench Peg & Anvil
Bench Peg & Anvil
- Cast iron and beechwood
- Clamps to a table or workbench, max thickness 35mm
- Jeweller’s saw board and anvil
This useful device has a multifunctional use for the serious jewellery maker or silversmith. Firstly, there’s a beechwood sawing board which slides into a heavy cast iron boss. Once in place, the boss can be clamped by means of a tommy bar to a table or workbench with a maximum thickness of 35mm. Secondly, the surface of the boss (80 x 70mm) has been ground flat allowing it to be used as a convenient anvil. It should be noted that before use as a saw board, a 'V' shape would be required to be made in the beech insert.
EAN Barcode | 5052511101030 |
- Standard Delivery* - £1.99
