Bow 36" XT XTENDER Fence
- Upgrade and extend compact saw fences
- Clamps quickly to existing fences
- Heavy duty aluminium extrusion for durability
- Enhance versatility: tall fence, T-slots for accessories
If you're looking for how to extend your table saw fence, the BOW Xtender Fence range is what you need. It's compatible with compact, portable, and cabinet table saws. For your bandsaws, this is the perfect saw fence upgrade to extend small table surfaces, especially when used with the additional feed support options.
Upgrade your saw fence on a wide range of powered saws with the BOW XT Xtender Fences, suitable for compact benchtop table saws, portable saws and bandsaws. Use the BOW Xtender Fence 36" combined with the XT Feed Supports (Pack of 2) as a table saw fence extension kit for your portable table saw - you will transform your saw and drastically improve its capabilities and feed control.
The benefit of using the XT Xtender Fence is unparalleled control and safety when feeding large pieces of timber through your saw. It is remarkably versatile and easy to use - you can set up, remove and change fence positions in seconds, making it incredibly convenient for a busy site or workshop. The XT Xtender Fence is designed with multiple T-slots and attaches effortlessly to your existing fence using two BOW XT T-Track clamps, which are available separately in pairs.
Engineered in a heavy duty aluminium extrusion for durability and strength, it's 36" long, 5" in total height and 1" wide. There is a 4" flat face on the front, ensuring your workpiece glides smoothly along it; as well as a T-slots on the face, top and back for easy compatibility with fence accessories. It features a handy hanging hole for easy storage. Multiple milled slots allow the fence to be positioned in a versatile range of positions: forward/infeed, centre, or back/outfeed.
As well as this 36" size, the BOW XT Xtender Fence is also available in 24" and 46". BOW produce a range of fantastic saw accessories including FeatherPRO Featherboards and PushPRO Push sticks; in the XT Xtender range, there are XT T-Track Clamps (Pack of 2) and XT Feed Supports (Pack of 2).
