UJK Machine Aligning Jig
- A simple tool to set up table saws, you can use it to measure the following:
- Align the blade to the mitre slots
- Align the fence to the mitre slot
- Check the axial run-out of the blade
- Check the axial run out of the blade flange
- Check the axial run out of the blade arbor
It is important to get the best from your saw, an accurate set up guarantees accurate results. The UJK Aligning Jig is a highly accurate jig that is simple to use. On a table saw you can measure:
The alignment of the blade to the mitre slots
The alignment the fence to the mitre slots
The axial run-out of the blade (the side to side wobble you see if the blade is turned slowly)
The axial run out of the blade flange
The axial run out of the blade arbor
Based on a simple mounting bar that fits any standard 19mm (3/4") mitre gauge slot, the mounting bar has adjustable spring loaded balls to ensure a snug fit, plus levelling screws to accommodate differing depths of mitre slot. This metric versions dial indicator reads in increments of 0.01mm with a total travel of 10mm. An invaluable tool in any workshop.
| EAN Barcode | 5052511127184 |
