Shaper Roughing Router Bit 8 x 35mm 8mm Shank
- 8mm dimeter with a 35mm depth of cut
- Solid carbide, 3 flute design
- Designed for rough passes with a high feed rate
This solid carbide 8mm cutter has a generous 35mm cutting length which can take advantage of more of Origin’s Z-axis travel range. Designed for rough passes with a high feed rate, the increased pass depth makes your Origin projects more efficient with no compromise on cut quality or stability. Suitable for a wide range of materials from foam to hardwood, the triple fluted design offers a quieter cutting experience and longer service life. Save time when changing bits thanks to the marked shank for accurate collet clamping.
Overall Length: 80 mm
Shank Diameter: 8 mm
Cutter Diameter: 8 mm
Cutter Length: 35 mm
Usable Length: 45 mm
Geometry: Upcut, Spiral, 3 flute
Material: Solid Carbide
D = Overall Diameter | 8 mm (5/16") |
EAN Barcode | 859790007733 |
Shank Diameter | 8 mm |
X = Depth of Cut | 35 mm |
- Standard Delivery* - Free
