Small, but mighty!
The PD15BDS Belt and Disc Sander is ideal for detail work, shaping, finishing, profiling and more. It’s small, yet mighty design ensures that you can complete all your craft tasks with ease.
A yellow and black  belt sander with a red abrasive belt, shown on a wooden workbench against a light grey brick wall.
Conveniently compact
Easy to store when not in use, the compact design makes the sander ideal for those with smaller workspaces.
A yellow and black PERFORM belt sander in use, with a person's hands guiding a piece of wood against the sanding belt in a workshop setting.
Compounds and mitres
The belt & disc table can be tilted to 45° and features a mitre slot, so both mitres and compounds can be sanded.
A person's hands changing the belt on a black and yellow Perform belt and disc sander
Quick and easy belt change
The belt can be changed with ease to make switching between applications a breeze.
A close-up of a yellow and black belt and disc sander, with a person's hand adjusting the disc position, revealing hook and loop Velcro on a wooden workbench.
Hook and loop discs
Hook and loop velcro discs are used to make disc changes easy and quick and saves adhesive residue being left on the machine.
A yellow and black belt sander with a dust collector hose connected, shown on a wooden workbench with a person's hand holding the hose.
Safeguard your health
Connect your belt and disc sander to a suitable vacuum extractor via the 2 x 35mm dust ports.
A close-up of a person's hands using a yellow and black belt and disc sander to sand a small piece of wood on a wooden workbench, with a dust collector hose connected.
Perfect for...
Excellent for detailing, shaping, finishing and profiling. It’s ideal for end grain, work fine-tuning angles and achieving mitres and compounds with ease.
The right grit makes all the difference
From rough shaping to a fine finish, having the right abrasive for each stage makes your projects look their best. Explore our selection and find the perfect grits for your work.
The Perform PD15BDS Belt & Disc Sander 230V is ideal for detailing, shaping, and finish sanding. It features a 25 x 762mm belt and a 145 x 145mm tilting table for profiling and finishing. The 125mm disc abrasive and 170 x 95mm table are perfect for end grain work and fine-tuning angles. Both tilting tables allow for precise detail work and achieving mitres and compounds with ease.
The machine includes two 35mm dust extraction outlets for both the belt and disc, a hook and loop sanding disc and belt, a mitre gauge and a support bolt. It's perfect for various beginner hobby and craft workshop applications and is especially suited to those with a smaller workspace.
Please note these machines are designed and manufactured for sanding wood and similar materials. It should not be used to abrade or grind metal.
Please note, if you require an EU plug, please ensure you purchase 113504
Belt Speed 840 m/min
Dust Extraction Outlet 30 mm I.D. / 35 mm O.D.
Overall L x W x H 320mm x 340mm x 385mm
Power 250 W
Rating Occasional Use
Abrasive Belt Size 25 mm x 762 mm
Plug Fitted UK 3 pin plug
Model PD15BDS
Abrasive Disc Diameter 125 mm
Disc Speed 2,980 rpm
Nett Weight 8.9 kg
Table Size, Belt 145mm x 145mm
Table Size, Disc 170mm x 145mm
Voltage 230 V
Warranty Perform 1 Year Warranty
EAN Barcode 5052511142132
