Formech FLB500 Line Bender
- Create sharp bends in plastic sheet easily and quickly
- Long bending length, up to 500mm long
- Maximum thickness 10mm
- Incoloy heating element for fast heating of material
- Fitted material clamp and temperature regulator
- Bending/cooling jig helps achieve required angle
Formech 450DT Desktop Vacuum Forming MachineFrom £4,458.78 £3,715.65
Formech 508FS Vacuum Forming MachineFrom £10,432.78 £8,693.98
The FLB500 is a manually operated machine that is capable of producing high quality bends in plastic sheets up to 10mm thick, from standard materials up to 500mm wide.
Operating from a normal 230V domestic electrical supply the FLB500 Line Bender is easy to use and devoid of any complicated controls. In education the machine is ideal for training applications where students are tasked to produce items in a range of materials and thicknesses. In industry it can help produce machine guards or display accessories e.g. menu holders, price holders etc. The Formech FLB500 comes complete with a dedicated cooling jig designed to maintain the desired angle of the heat-bent plastic whilst cooling.
EAN Barcode | 5052511120789 |
Max Material Thickness | 10 mm |
Max Width | 500 mm |
Model | FLB500 |
Nett Weight | 8 kg |
Overall L x W x H | 680 mm x 175 mm x 330 mm |
Voltage | 230 V |
This product is classified as an Enquiry product. Enquiry products require contact with our friendly team prior to purchase to understand your requirements. Typically these products have many customisation options or require product training.
Enquiry products are usually readily available and often despatched directly from the manufacturer using the best delivery service available. Despatch times can vary between manufacturers and delays may occur should stock become unavailable. Please contact customer services for more information.
