Dado Joint
A dado joint, also known as a housing joint or trench joint, is a woodworking joint where you create a rectangular groove or channel across the grain of a workpiece to accommodate another piece of wood. It is a popular choice for when you need to join shelves to cabinet sides, create dividers in drawers, or want to construct bookcases.
Here's a step-by-step overview of how to create a dado joint:
- Mark the location: Determine the placement of the dado joint on both the mating workpieces. Use a marking gauge, a combination square, or a measuring tape to accurately mark the location of the joint.
- Set up the cutting tool: Choose a cutting tool appropriate for the dado width and depth. Options include a dado blade on a table saw, a dado router bit, or a hand saw and chisel.
- Adjust the cutting depth: Set the cutting depth of the tool based on the desired depth of the dado joint. It's essential to make multiple passes if needed to achieve the desired depth while avoiding excessive strain on the cutting tool.
- Secure the workpiece: Clamp the workpiece firmly to a workbench. Alternatively, use a suitable holding device to ensure stability during the cutting process.
- Cut the dado: Use your chosen cutting tool to remove the wood material within the marked area to create the groove. Make straight cuts along the marked lines and maintain proper control of the tool throughout the process.
- Test the fit: After cutting the dado joint, test the fit by placing the mating workpiece into the groove. It should fit snugly but not be too tight or loose. Make any necessary adjustments or fine-tuning to achieve a proper fit.
- Glue and assemble: Apply wood glue to the mating surfaces of the joint and assemble the pieces together. Use clamps or other appropriate means to hold the joint securely until the glue dries and the joint is fully set.
Dado joints provide a strong and reliable method for joining pieces of wood, especially for applications that require structural support or shelf placement. They offer stability, increase glue surface area, and help prevent shifting or sagging over time.
Discover more...
If you’ve enjoyed reading this article, keep an eye out for more woodworking articles to develop your knowledge and skill over time.
Get connected!
Follow us on Instagram and Facebook to stay up to date on all the latest from our Woodworking Wisdom platform. Connect with us @AxminsterTools.
