Festool CXS 18-Basic Set Cordless Drill 18V (Body Only)
- Powerful cordless drill driver set for effortless working
- Compact, ergonomic design for ease of use
- FastFix spindle takes full range of accessories
- LED light for work in poorly lit areas
- Battery and motor protection for prolonged tool life
- Low weight for convenient drilling and fastening
- CENTROTEC system for fast and simple accessory change
- FastFix elbow adaptor gets into very tight areas
- 2 chucks - 10mm FastFix chuck and CENTROTEC tool chuck
- Supplied in Systainer SYS3 M 137 case with lid compartment
UJK Hex Shank Drill Adaptor 10mmFrom £7.38 £6.15 -
UJK Hex Shank Drill Adaptor 8mmFrom £7.38 £6.15 -
UJK Hex Shank Drill Adaptor 4mmFrom £7.38 £6.15 -
Festool Li-Ion Bluetooth Battery 18V (4.0Ah)Special Price £109.98 £91.65 was £126.98 £105.82 Save £17.00 £14.17 -
Axcaliber FineLine PTFE Coated HandsawFrom £12.31 £10.26 was £13.68 £11.40 Save £1.37 £1.14 -
Axminster 7 Piece Forstner Bit SetSpecial Price £25.48 £21.23 was £29.98 £24.98 Save £4.50 £3.75
Meet your practical and powerful companion
This compact and neat cordless drill driver will surprise you with its impressive 18V power. Tackle any task with ease with the CXS 18.
Surprisingly compact
Enjoy the combination of a small and light design. With a length of 140mm and height of 224mm, it is very compact. This will be your practical everyday companion.
Effortlessly powerful
Compactness coupled with the impressive 18V battery power. Thanks to the Festool EC-TEC brushless motor, your battery wiil last longer, whilst delivering efficient energy.
Reach the smallest of spaces
The angle attachment is perfect for work around tight spaces and reaching hidden screws at tricky angles.
Equipped for every application
Interchange between screwdriving and drilling seamlessly, with 12 torque settings and one drilling mode. The FastFix interface allows rapid change of drilling heads. Connect all Festool screwdriver and drill accessories with the fast CENTROTEC bit change system.
Everything is close to hand
The practical integrated bit magnetic holder provides space for multiple bits, preventing them from falling out. Also supplied with a belt clip, saving time and effort.
Impressive lighting
The integrated LED light allows you to work precisely, even in dark corners. Personalise the afterglow brightness in the Work App.
Intelligent settings in the Work App
Easily configure to right or left-handed use, in the clever Festool Work App. Simple to pair, connect with a Bluetooth battery pack. Convenience at its finest.
MyFestool
Festool offer a comprehensive service plan once you register your tool. Enjoy the following benefits with the Warranty all-inclusive:
- Free repairs for three years
- Fast resolution directly from Festool
- Replaced in the event of theft
Power and performance in a compact cordless tool, add in the high build quality and long service life and you have the Festool CXS 18. The power is provided by a Festool 18V battery, combined with the maintenance free brushless E-Tec motor gives you unrivalled performance (note this is a body only tool).
As with all Festool tools every aspect has been designed to ensure you have full control. The CXS 18 is designed for everyday use for light to medium screwdriving and drilling applications. The power, low weight and impressive ergonomics make drilling and fastening almost effortless. The CXS 18 will bore a 35mm hole with a Forstner bit or drive a 6 x 240mm screw into softwood.
The FastFix interface makes the CXS 18 fully compatible with the full range of Festool FastFix attachments. It comes with the CENTROTEC tool chuck, offering practically instant changing between drilling, countersinking and screwdriving bits. In addition the Basic SET includes a 10mm FastFix keyless chuck and FastFix angle attachment. Note, 1/4" hex bits can be inserted directly into the FastFix spindle for screwdriving or drilling in cramped spaces. The CXS 18 comes equipped with an LED light for working in those cramped dark corners. A practical integrated bit holder provides storage space for 1/4" hex bits, magnetically secured to prevent them falling out
Supplied with: FastFix BF-FX 10mm keyless chuck, CENTROTEC WH-CE tool chuck, FastFix AN-XS 90 angle attachment, CENTROTEC BH 60 CE 1/4" hex magnetic bit holder, BKS SYS3 D5 PZ TX 100 CE 5 piece 100mm long 1/4" hex CENTROTEC screwdriver bit set, 1/4"Hex screwdriver bit PZ2, belt clip and a Systainer SYS3 DF M 187 carry case with lid compartment
Note: this is a body only tool supplied without batteries or charger.
In order to take advantage of the Festool Warranty All-Inclusive, you will need to create a MyFestool account and register your tool within 30 days of purchase.
Benefits
- Includes 36-month machine guarantee
- Full repair, free of charge
- Replaced in the event of theft*
- Original parts guaranteed
- 14-day money back*
All Warranty claims are handled directly with manufacturer please refer to the warranty information supplied on registration for correct procedure.
Warranty issues outside of the UK - Please refer to the warranty in the home country and if a tool has to be returned to UK be aware that all postage costs would need to be arranged and paid by the customer.
Axminster Tools cannot register a Festool tool on a customer's behalf.
NB: For more information and *full terms and conditions visit the Service section of the Festool website.
Find out more| Batteries Included | Body Only Tool |
| Battery Type | Li-ion |
| Battery Voltage | 18 V |
| Chuck Capacity | 1 mm to 10 mm |
| Chuck Type | keyless |
| Corded or Cordless | Cordless |
| Drilling Speed | 0 - 470 rpm / 0 - 1,600 rpm |
| EAN Barcode | 4014549405710 |
| Length: [Front to Back] | 156 mm |
| Manufacturer Part Number | 577334 |
| Max Drilling Metal | 10 mm |
| Max Drilling Wood | 35 mm |
| Model | CXS 18-Basic Set |
| Nett Weight | 1.4 kg (with battery fitted) |
| Reverse | Standard Feature |
| Sound Power Level LwA [Uncertainty K] | 83 dB(A) [3.0 dB] |
| Sound Pressure Level LpA [Uncertainty K] | 72 dB(A) [3.0 dB] |
| Torque | 40 Nm |
| Torque Settings | 12 + Drilling |
| Vibration Drilling Metal [Uncertainty K] | 3.0 m/s² [1.5 m/s²] |
| Vibration Screwdriving [Uncertainty K] | <2.5 m/s² [1.5 m/s²] |
| Warranty Length | 3 Year |
- Standard Delivery* - Free
