EcoPoxy | Natural Epoxy & Resins For Woodworking
EcoPoxy - the go to epoxy for woodworkers, woodturners, crafters and more...
EcoPoxy offers an eco-friendly alternative to other epoxy resins on the market. Suitable for an array of crafts, the range of innovative epoxies is perfect for creating your own river tables, woodturning resin art and much, much more.
The environmentally friendly range of epoxies are manufactured by EcoPoxy; a leader in the research and development of high bio content epoxy resins. The safe, environmentally friendly range are low odour, plant based epoxies that are 100% solid and require no ventilation when using.
Natural Innovations
EcoPoxy offer bio-based, non-toxic epoxies which are an environmentally friendly alternative to other epoxy resins on the market. All over the world, customers are using EcoPoxy to create, build and beautify the space around them.
Versatile Creations
The eco-friendly epoxies empower you to imagine the possibilities, to create something out of nothing, to explore what is possible, to create a natural and versatile surface that allows you to find the artist in yourself.
The EcoPoxy range...
Flowcast® Casting Resin - perfect for thick pours!
FlowCast® is a casting epoxy resin that looks like liquid glass. When the two parts are combined, it hardens to a crystal clear, durable finish to a maximum thickness of 1.5". Use FlowCast® epoxy by itself for a crystal clear finish or pigments can be added to create custom colours and effects.
- No toxic organic compounds or heavy metals
- 100% solids, low VOC, low odour
- Crystal clear, high gloss
- Self-levelling
- Extremely durable
- Excellent air release quantities
- Excellent colour stability
- Impact resistant
Ecopoxy FlowCast Casting ResinFrom £0.00 £0.00
UVPoxy Coating Resin - coat and protect your surfaces with a crystal clear thin pour.
UVPoxy is a crystal clear, brilliant surface that accentuates and magnifies the material below it. Perfect for coating, bonding and more. The formulation produces a crystal clear, durable finish that resists yellowing, fading and cracking over time. As an ideal solution for woodworkers, artists and craftspeople, the UVPoxy Kit is a professional quality, high-performance epoxy system that is UV stable.
- 100% solids
- Crystal clear, high build finish
- Self-levelling, high gloss
- Extremely durable
- U.V. Resistance
- Excellent air release qualities
- Wets out substrates well
- Impact resistant
- Improves surface appearance
EcoPoxy UVPoxy KitFrom £0.00 £0.00
GloPoxy - the most powerful photo-luminescence available
GloPoxy is a glow-in-the-dark epoxy made with high-grade photo-luminescent ingredients that make sure your epoxy glows as bright as it can for as long as it can. The formula absorbs light as energy and releases this energy when placed in the dark. Durable, UV stable and resistant to chemicals, water and abrasion, it can glow for hours! Use GloPoxy on virtually any surface either indoors or outdoors.
Colour Pigment Dyes - add some colour to your epoxies
The Colour Pigment Dyes provides a rich and vibrant pigmenting solution for EcoPoxy products. The advanced tint properties allow you to do more with less when compared to other pigments. They’re easy to mix together and if you’re looking for something different why not have a go at mixing multiple dyes together!
EcoPoxy Colour Pigment Dyes - Set of 8 x 60mlSpecial Price £76.38 £63.65 was £96.38 £80.32 Save £20.00 £16.67
EcoPoxy Metallic Pigment - create pearlescent and iridescent effects
Metallic Colour Pigments are special effect pigments composed of mica nanoparticles coated with various organic and inorganic colours. This creates pearlescent and iridescent effects that mimic the natural look of stone and rock formations. Blend EcoPoxy Metallic Colour Pigments with EcoPoxy or similar resins to produce an unlimited array of custom effects. The pigmentation of the underlying colours will also influence their translucent nature. With the natural stone appearance, these extremely durable colour pigments are suitable for many environments.
Available in the colours below:
EcoPoxy Colour Glitter - make your world sparkle
Also available are 12 unique glitter colours; precisely cut from premium vacuum-metalised polyester film, the colour glitters are compatible with EcoPoxy Resins. They can be blended to create a lustrous look that enhances your project and compliments your decor.
Discover Lizard Blanks resin and casting moulds
Casting your own blanks gives you full control over colour, effects and even encapsulating other objects in the resin! Lizard Blanks use UHMW (Ultra-High Molecular Weight) plastic in the construction of these superior resin-casting moulds. This material is highly wear resistant and allows the easy removal of a cured casting.
Get involved!
Comment below or send us a photograph and tell us all about your experience with EcoPoxy products. Alternatively, get in touch via our social media platforms. Find us on Facebook, send us a tweet or connect with us on Instagram. Don’t forget to use the hashtag #ecopoxy to @AxminsterTools.
Is epoxy resin food safe? Will it ever leach?
Hi Alex, apologies for the delayed reply. Regretfully we cannot claim that EcoPoxy is food safe. EcoPoxy themselves advise that when the resin is mixed at the correct ratio and fully cured it has few unreacted components, but some non-reacted components can always be extracted. None of the unreactive components are acutely toxic but the resins have not been tested. I hope this helps.
Is this epoxy suitable for wood turning?
Hi Denis, yes EcoPoxy is suitable for woodturning. Our resident Woodturners use the epoxy for a variety of woodturning projects. Many thanks.
Is this safe for kids to use?
Hi Desirae, Thank you for getting in touch. The manufacturer says that once cured the resin is child safe. However, we would recommend against letting children use the resin in craft projects, as it could be harmful, particularly if ingested. Please contact the manufacturer directly for further advice with this regard. Regards, Lisa
So you mention the ecopoxy is 100% plant based. Is that all the range including the colours too?
Hi Mary, thank you for getting in touch. We have been advised by EcoPoxy that the colours and pigments are made using Mica powder, which is made from a natural rock. For any further advice on this we would advise you contact the manufacturer directly. Hope this helps. Regards, Lisa
Hi would this epoxy work to refinish a clawfoot tub?
Is EcoPoxy safe to cut with a co2 laser after it has cured?
I am working on a carving project at the moment and the wood I've chosen is one of the hardest woods I know to work with, Pacific Madrone. My question is, does exopoxy offer a product that would work to provide a top coat and simultaneously fill the many, and some fairly large, cracks that have appeared as the wood has dried? Also, if such a product is available could someone provide a few pointers on how to go about applying the resin? My end goal is to hopefully fill the cracks with a tinted resin and then top coat the entirety of the piece for long lasting protection.
I am highly allergic to resin. I have tried sooo many and still had a reaction. Would your product be safe for me to try
Hi, would you be able to advise me.. I am making cosplay masks and wondered if this ecopoxy would be safe to wear on the face. I don’t want it to be toxic or have a strong smell.
Thank you
Hi Laura, EcoPoxy have stated its products are non-toxic and many use them for jewelry that they are wearing all day. EcoPoxy say If the project is done according to application instructions, there should be no odor. And they would recommend washing the mask before wearing it, in case there is any unmixed raw part A or B on the surface. I hope this helps. Lisa
Is this suitable for using in epoxy resin molds (e.g. silicone molds for crafting)?
Hi Bonnie, Thank you for your question. Yes, EcoPoxy is safe to use in epoxy resin molds as you suggest. Hope this helps. Lisa
Can you use this product in a pressure pot?
Hi, is it biodegradable?
We build E Bikes and Scooters out of laminated wood and use normal epoxy as the glue between the 3 to 4 mm wood strips. How strong is ecopoxy as glue ?
