Router Tables
If you’ve ever tried to run delicate profiles on narrow stock or repeat accurate grooves across multiple parts, a router table quickly becomes the hero of the workshop. It turns a handheld router into a stable, repeatable station—adding precision, control and safety to everyday routing tasks.
Router Tables
A router table is more than a flat surface with a hole in it. It’s a complete system: a rigid tabletop, a straight and adjustable fence, accurate height control, dust extraction, safety aids (like feather boards), and the right inserts and guide bushes for your router. Together, these components unlock clean edge mouldings, accurate rebates, groove and dado work, template routing, coping and mitre operations—and they do it with a level of repeatability that’s hard to achieve freehand.
What is a router table?
At its core, a router table mounts your router (or a dedicated router motor) beneath the tabletop so the cutter protrudes through an insert plate. Your work travels over the table and past the cutter, guided by an adjustable fence and safety aids. Better tables feature: cast iron tops for vibration damping and flatness, precise fences with dust ports, mitre/T‑tracks for jigs, and above‑the‑table height adjustment via a router lift.
Why woodworkers need one
- Accuracy and repeatability
The fence, tracks and lift let you dial in cuts and repeat them across batches—ideal for cabinet doors, frames and mouldings. - Safety and control
Feather boards and a guarded fence keep hands clear while maintaining constant pressure against the fence and table, reducing chatter and kickback. - Cleaner workflow
Purpose‑built extraction from above and below the table keeps visibility high and clean-up low. - Versatility
Swap insert rings, add guide bushes/adaptors, or upgrade to a dedicated UJK motor for a seamless, long‑term station. - Investment that grows
Start with a compact or laminated‑top package and expand with lifts, fences, coping sleds and NVR switching as your projects evolve.
Router tables - A quick overview
- UJK Professional Router Table — cast iron top, heavy‑duty stand, pro fence; ideal for serious hobbyists and pros.
- UJK Compact Router Table (Cast Iron) — smaller footprint, same stability; perfect for space‑limited workshops.
- UJK Router Table with Laminated Top — value bundle (top + fence + stand) with smooth phenolic surface.
- UJK Portable Trim Router Table — benchtop, made in Britain, for palm / ¼″ routers and small precision jobs.
Router table accessories
Height control
UJK Router Lift for above‑table adjustments.
Router Lift Complete Package if you want lift + motor in one go. -
Motors
UJK Motor & Mount — 1800 W, variable speed, ER collets (¼″, ½″, 8 mm, 12 mm).
Fences
UJK Professional and Compact fences with dust ports, T‑slots and fine adjusters.
Insert plates and rings
Phenolic or aluminium plates; insert rings (12.6 mm, 38 mm, 63.4 mm, guide‑bush adaptor).
Guide bushes and adaptors
Stainless sets and adaptors to match common routers; great for template work.
Dust extraction
Below‑table Dust Extraction Box links to above‑fence port for dual extraction.
Safety and control
Feather boards (vertical/horizontal), Coping Sled, NVR Switch for safe power control at the stand.
Final thoughts...
Whether you’re upgrading to a cast‑iron pro station or adding a compact bench‑top table, the UJK ecosystem at Axminster Tools lets you build a router setup that grows with your skills. Start with the table that fits your space, add a lift for precision, lock in safety and cleanliness with fences, featherboards and dust extraction, and round it out with guide bushes/adaptors for template work. The result: faster setups, cleaner cuts and repeatable accuracy project after project.
Discover more...
If you've enjoyed reading this guide, why not take a look at some of our blogs?
Get in touch!
Get in touch via our social media platforms. Find us on Facebook or Instagram.
