The 10 Tips You NEED to Know About Dust Extraction
Dust extraction is essential – really essential. But figuring out what you need, how to choose, and how to install it can be confusing! We’ve quizzed our experts to give you the essential top ten tips of workshop dust extraction.
1. Bigger is better!
Over spec your extraction wherever possible. It’s better to have a system that’s too efficient than one that can’t keep up with you.
2. Keep all of your rigid pipework as straight and short as possible
For this reason, choose Y junctions over T shapes.
3. Clean and replace your filters!
Sounds simple enough, but by looking after your filters, they will look after you.
4. Seal all your system joints so that there are no leaks
Otherwise, you risk losing suction power through your leaks and having dust escape into your workshop.
5. Use blast gates at every station
By positioning a blast gate in the ducting run before every machine, you can close the gates to isolate machines not in use. Get the full benefit of extraction on the machines you are using!
6. Earth all rigid plastic pipework
This essential step prevents static build-up and reduces fire risk.
7. Keep flexible pipe to a minimum where possible!
Flexible pipe can reduce airflow and increase blockages if used too much instead of rigid ducting.
8. Choose the right type of extractor
Opt for LVHP for power tools and small machines, and pick HVLP for larger machines.
9. Upgrade your dust collection
Use fine filters to effectively capture even the smallest dust particles. Add an interceptor to your system to grab large debris before it hits your filters. Fine filters and interceptors work together to maintain high suction power!
10. Make the most of every tool at your disposal
Use PPE (personal protective equipment) and LEV (local exhaust ventilation) extraction, as well as your dust extraction system. Your safety is paramount – there’s no replacement for you!
We're a one stop shop for extraction
You are now fully equipped with everything you need to know about your dust extraction. But... is your workshop kitted out?? Take your newfound know-how and explore our range today. There are extractors of every type, kits, adaptors, clips and more plus metal ducting and hoses of every description!
Shop Extractors Shop Extraction AccessoriesWould you like more advice?
If you’d still like to chat about what’s best for your workshop, feel free to give us a call or email us for advice. Get in touch here!
