Spray smarter and finish faster
Compact, portable, and packed with smart features, the (Diamond) D6 is everything you need for flawless finishes, job after job.
Delivers exceptional power with a maximum PSI of 11.5, ensuring even coverage and a stunning finish.
Engineered for efficient and cooler operation, the D6 ensures unmatched longevity, whether used in the workshop or on site.
Provides consistently warm, dry air, atomising even the highest viscosity coatings - such as latex and urethane – with little or no thinning required.
Six-stage pressure control ensures accurate, repeatable results with a simple button press.
Power the unit on/off remotely—no need to unplug or return to the base.
Flip-out holder stores gravity-feed guns neatly without a separate stand.
Dual filters with easy access caps keep the turbine clean and running smoothly.
Lightweight design with ergonomic grip makes it easy to carry and store.
Choose from the T75G Gravity, T70 Suction or G-Xpc Gravity spray guns.
They all feature a non-bleed lightweight HVLP design which reduces fatigue, turbulence and dust in the spray area. A side-mounted fan pattern control allows for quick adjustments between horizontal, vertical, and circular spray patterns. The Fuji Spray tilt feature allows the user to spay in any direction, including upwards.
600cc pressurised gravity cup. Ideal for precision work and fine finishing projects, especially where control and manoeuvrability are key.
950cc pressurised suction cup. Ideal for larger-scale projects and professional-grade finishes, particularly in woodworking, cabinetry, and automotive refinishing.
400cc pressurised gravity cup. Ideal sized gun for projects such as inside cabinets, furniture, bath restoration and spray body tanning.
Suggestions on usage should be used as a guide only. Experimentation is the best method to determine which setup performs best for your desired coating.
Setting 1: Thinner viscosity products. Shading and toning stains, inks, touchups, and dyes.
Settings 2-3: Automotive enamels, airplane and marine finishes, nitrocellulose lacquers, pre-cat lacquers, shellacs, sealers, acrylics, synthetics, polyurethanes, stains and varnishes.
Setting 4: Catalysed lacquers, primers, varnishes, urethanes, enamels, high viscosity industrial coatings, sealers, polyurethanes, oil-based paints, epoxy enamels, plastics, floor paving paints, latex (walls and ceilings), and multi-fleck paints.
Settings 5-6: Stone finishes, texture coatings, industrial primers, water-based 2K acrylic topcoats, high viscosity industrial coatings, and nitrate dope.
The Fuji D6 sets a new standard in turbine paint sprayers. With greater control, minimal overspray, remote operation, and the ability to spray thick paints effortlessly it’s the ultimate all-in-one turbine setup.
Designed for professionals and serious DIYers, the D6 features a powerful 6-stage motor rated at 11.5 PSI, delivering exceptional performance across a range of applications. It is available with three spray gun configurations to suit different needs. The T75G comes with a standard 600cc top-mounted gravity cup and features a non-bleed design, a side-mounted pattern control knob for easy fan size adjustment, and continuous positive pressure during spraying. The T70 includes a large 900cc bottom-fed fluid cup and shares the same non-bleed design and side-mounted pattern control for consistent, smooth application. For more detailed work and tight spaces, the G-XPCâ„¢ spray gun offers a compact, lightweight body with a 400cc gravity-fed cup, an ergonomic angled design for better balance, and a side-mounted pattern control knob. Its non-bleed operation ensures cleaner results with reduced overspray.
The Fuji D6 is designed to handle high-viscosity coatings with minimal or no thinning required, making it ideal for spraying latex and urethane paints straight from the can. This eliminates the need for time-consuming prep work and ensures a smooth, professional finish.
Engineered for efficient and cooler operation, the D6 is designed to prolong motor life and maximize return on investment. Unlike traditional turbine sprayers with a dial, the D6 uses six distinct pressure stages that can be selected at the touch of a button. This allows you to replicate precise spray settings every time, which is especially valuable for repeat projects and professional jobs. An integrated wireless remote control is built into the system, letting you turn the turbine on or off without walking back to the unit. This improves workflow efficiency and gives you more control over your setup.
The D6 features a convenient flip-out gun holder that folds away into the unit when not in use. This is particularly useful for gravity-feed guns and saves space without needing a separate stand. It also includes an upgraded dual-stage filtration system, featuring a high-efficiency pleated filter and foam pre-filters on both ends of the turbine. These filters are easy to access and replace, helping to protect the internal components and extend the life of the unit.
Designed with portability in mind, the D6 has a compact, ergonomic form with a large carry handle, making it easy to move around your workshop or transport to the job site. Finally, the D6 comes with a full kit of accessories - including a 9m flexible whip hose, 1.8mm air cap set, 19-piece gun cleaning kit, wet film gauge and spare filters - so you can get started right away with everything you need for professional-grade results.
