Hermes RB 377 YX Abrasive Belts 50 x 785mm
- Universal belts for sharpening and grinding
- High stock removal rates in the coarse grit range
- Consistent surface quality in the fine grit range
- Polyester/cotton cloth backed aluminium oxide abrasive
Axminster 7 Piece Forstner Bit SetSpecial Price £25.48 £21.23 was £29.98 £24.98 Save £4.50 £3.75 -
Axminster Combination Square Metric 300mmSpecial Price £15.20 £12.67 was £17.88 £14.90 Save £2.68 £2.23 -
Axcaliber FineLine PTFE Coated HandsawFrom £12.31 £10.26 was £13.68 £11.40 Save £1.37 £1.14 -
Cloth backed belts in a choice of grits. The polyester/cotton back combined with the resin bonded aluminium oxide grain mix produces a high stock removal with coarse grits, plus a consistent surface quality with finer grits. Smooth running and long lasting, RB 377 YX abrasive is perfect for abrading metals.
| Abrasive Backing | Cloth |
| Abrasive Belt Length | 785 mm |
| Abrasive Belt Width | 50 mm |
| Abrasive Material | Aluminium Oxide |
| Abrasive Type | RB 377 YX |
