Invest in solutions
Laguna Tools are synonymous with precision, power, and performance. Their tools are meticulously designed to ensure a flawless execution of every project. With Laguna, you’re not just purchasing machinery, you’re investing in solutions. Explore our blog to learn more about the exceptional range of Laguna machines, exclusively available through Axminster Tools and our trusted partners in Scotland and Northern Ireland.
Work with confidence
UKCA-Certified excellence and comprehensive warranty
All Laguna Tools UK adhere to current safety regulations and include a one-year warranty as standard, with an optional extended warranty for a second year.
Air Filtration
A superior air cleaner, cleverly designed for quiet, high-level purification and smart energy conservation.
  • Hassle-free maintenance: Inner 1-micron and outer washable 5-micron filters
  • User convenience: Air filter indicator and remote control
  • Energy efficient: 150W motor balances strong performance with low energy consumption
  • High-level air purification: Recycles all of the air in a 6m x 6m x 2.4m space by up to 22 times/hour
  • Auto-off feature: Built-in timer settings of 30 min / 2hrs / 4hrs allows for air cleaning, even after work stops
  • Quiet operation: Maintains a low sound level between 55.6dB and 59.6dB across different speed settings
  • L 712mm W 610mm H 305mm Weight 25kg
Motor
150W
Max Airflow (low/med/high)
917 / 1240 / 2038 m3/hour (540, 730, 1200 CFM)
Outer Filter
5 micron washable electrostatic filter
Inner Filter
1 micron polyester
Filter Cycle
10, 14, 22 times per hour
Optimal Workshop Size
6m x 6m x 2.4m (20’ x 20’ x 8’)
Auto-off Timer Settings
30 minutes / 2 hours / 4 hours
Sound Level
Up to 59.6dB
Unlock the full potential of your machine with the extensive range of Laguna accessories.
Bandsaws
Meticulously engineered for unwavering stability and pinpoint precision.
Greater cutting accuracy
  • 10-point ceramic guides: Positioned above and below the table, ensure easy setup and precise cuts, even for deep timber resawing
  • Pyramid-shaped spine: Minimises frame distortion when the blade is fully tensioned
  • Fully adjustable Hi-Lo fence: Enhances versatility, allowing for precise cuts across various materials
  • Table insert adjustment: For simple levelling
  • Table Tilt: From -7 degrees to +45 degrees
Trouble-free operation
  • Double windows: Allows you to check both tension and tracking while the machine is running
  • Quick-release blade tension lever: Allows faster blade changing
  • Solid cast wheels with polyurethane tyres: Provides cooler operation and longevity
  • Ultra-smooth worm gear and pinion: Has minimal flex for consistent and accurate cuts
14|12 Bandsaw
14BX Bandsaw
18|BX Bandsaw
Maximum Cutting Depth
330mm
330mm
405mm
Maximum Cutting Width (with fence)
310 mm
310 mm
400 mm
Motor
1.3kW
1.9kW
2.86kW
Aluminum Fence (Hi/Lo) Height
140mm / 12mm
140mm / 12mm
185mm / 16mm
Foot Operated Disc Brake
Table Size (Cast Iron)
400mm x 546mm
400mm x 546mm
500mm x 660mm
Dust Collection Outlet
100mm single
100mm twin
100mm twin
Blade Length
2,921mm
2,921mm
3,673mm
Blade Width Capacity
3mm to 19mm
3mm to 19mm
3mm to 32mm
Drum Sanding
Supermax16|32 Drum Sander 230V
A compact powerhouse, engineered for top-tier efficiency and precision, ensuring professional-grade sanding performance.
  • Open ended drum: Allows 810mm maximum sanding width in two passes, enhancing the sander’s versatility and capacity for larger projects
  • Patented quick adjust lever: Allows full height adjustments with one pull of a lever and finer adjustments with the hand wheel, significantly reducing set-up time and boosting productivity
  • Built-in digital read out: Ensures consistent thicknesses for increased accuracy and quality of output
  • INTELLISAND technology: Variable speed conveyor table automatically adjusts to maintain a consistent finish, accommodating varying grain patterns and densities
  • Turbo vented dust port: Increases air-flow to a dust collector by 15%, enhancing dust removal
  • Perfect feed alignment: The drum carriage is bolted to the base, eliminating movement or alignment issues
  • Low Price
    Laguna 16-32 Drum Sander 230V
    5. Half Star
    (5)
    Special Price £1,169.99 £974.99 was £1,299.98 £1,083.32 Save £129.99 £108.32
Drum Motor
1.1kW
Conveyor Motor (DC)
40w
Maximum Width (1 pass)
405mm
Maximum Width (2 passes)
810mm
Minimum Length
57mm
Maximum Thickness
75mm
Minimum Thickness
0.8mm
Drum Dimensions
127mm x 405mm
Drum Speed
1,400 rpm
Conveyor Speed (Variable)
0-3 m/min
Dust Collection Minimum Requirement
1,000m3/h (600cfm)
Dust Port Diameter
100mm
Dust Extractors
Innovative machines designed for user convenience and operational effectiveness
B|Flux 1 Dust Extractor 230V
  • Compact design: Easy stores away when not in use
  • High-quality filtration: 1-micron pleated, to maximise airflow
  • Easy bag change: With patented Snap-Band
  • Simple manual cleaning: Crank handle drives paddle
Motor
750W
Airflow
884m3/hr (520 CFM)
Filtration Efficiency
99.7% @ 1 micron
Inlet Diameter
100mm
Impeller Fan Type
229mm steel radial fin
Drum Collection Capacity
Bag layflat size, 600 x 900mm
Filter Canister Cleaning
Manual crank
Sound Level
76 dB
C|Flux 1 Cyclone Dust Extractor 230V
  • Superior cyclone performance: Two stage separation of chips, shavings, and fine dust particles
  • Smart lift chip drum: Engages with a simple lever action, with level senses
  • Efficient manual cleaning: Dual paddle design, rotated by a crank
  • Remote control: Easy operation from a distance
C|Flux 3 Cyclone Dust Extractor 415V
  • An increased motor power and capacity: ideal for continuous use and reduces the need for frequent emptying
P|Flux 1 Cyclone Extractor HEPA 230V
  • HEPA filtration: Extracts down to 0.4 micron
  • Fully automated cleaning: Paddle automatically begins cleaning every 10 minutes
  • Automatic drum full alert: Complete with warning light and audible alarm
  • Smaller in size compared to the P|Flux 3, this extractor has a capacity of 95 litres
P|Flux 3 Cyclone Extractor HEPA 230V or 415V
P|Flux 1
P|Flux 3
Motor
1.1kW
2.2kW
Airflow
1,786m3/hr (520 CFM)
3831 m3/hr (2253 CFM)
99.2% @ 0.4 micron
99.2% @ 0.4 micron
Inlet Diameter
1 x 150mm or 2 x 100mm
1 x 200mm or 3 x 100mm
Impeller Fan Type
340mm steel radial fin
390mm steel radial fin
Remote Control
Remote control
High frequency
95 litre octagonal drum
209 litre octagonal drum
Collection Drum Full Signal
Warning lights & audible alarm
Fully automated paddle cleaning
Sound Level
70 dB
76 dB
C|Flux 1
C|Flux 3
Motor
1.1kW
2.2kW
Airflow
1786 m3/hr (1051 CFM)
3,831 m3/hr (2,253 CFM)
99.7% @ 1 micron
99.7% @ 1 micron
Inlet Diameter
Impeller Fan Type
394mm steel radial fin
Remote Control
High frequency
High frequency
113 litre octagonal drum
175 litre octagonal drum
Manual crank
Manual crank
Sound Level
82 dB
99dB
Grinding
G8 Dual Speed Bench Grinder 230V
Precision and power for the perfect grind.
  • Dual-speed capabilities: 2,890rpm for heavy stock removal and 1,490rpm for precise sharpening and polishing
  • Two extra-wide flat Tool Rests: offers ample support, ensuring stability and accuracy. Adjustable lever and knob enable precise positioning for optimal grinding angles
  • 200mm x 25mm Aluminium Oxide Wheels: 60-grit for fast waste removal, 120-grit for sharpening, ensuring both efficiency and precision
  • Flexible LED light: enhances visibility, ensuring better accuracy and safety
  • Adjustable spark deflectors and 3X magnifier-equipped eye shields: protects the user while offering magnified visibility for detailed work.
  • Heavy cast-iron base with rubber feet: ensures stability and reduces vibrations, providing solid and secure grinding
  • Mounting slots in the base: provide secure attachment to a workbench, ensuring stability during use
  • Diamond wheel dressing tool and holder: keeps the grinding wheels in optimal condition
Motor
370 W
Speed Low
1,490 rpm
Speed High
2,890 rpm
Bore Size
16mm (5/8”)
Wheel Diameter
200mm
Wheel Width
25mm
Wheel Grit
60 Grit / 120 Grit
Wheel Material
White Aluminium Oxide
Nett Weight
17 kg
Light
Built-in LED
Eye Shields
3x Magnifying with angle adjustment
Tool Rests
Extra wide, Cast Aluminium
Lathes
Precision, power, and performance in every turn.
  • Cast-iron beds: Ensures stability and precision
  • Cast iron headstock, tailstock and banjos: Gives strength and low vibration
  • Belt change lever: Offers quick adjustment
  • Variable speed: Fine tunes speed efficiently
  • Forward and reverse rotation: For added versatility
  • Indexing positions: Improves detail in project designs
  • Spring-loaded spindle lock and self-ejecting tailstocks: Enhance safety
  • Digital speed readout: Enables speed optimisation for consistent quality
  • Projected nose cone with dual bearings: Gives additional accuracy and better work access
12|16 Lathe
18|36 Lathe
24|36 Lathe
Motor
DC permanent magnet, 750w
Induction VFD,1.5kW
Induction VFD, 2.2kW
Swing Over Bed
310mm
450mm
600mm
Swing Over Banjo
240mm
340mm
490mm
Distance Between Centres
390mm
910mm
910mm
Speed Range Low
50 – 525 RPM
50 – 1,300 RPM
50 – 1,300 RPM
Speed Ran High
650 – 3500 RPM
135 – 3,500 RPM
135 – 3,500 RPM
Tool Rest Length
150mm
305mm
305mm
Headstock Spindle Indexing
24 positions with lock
14/36/48 positions with lock
Tailstock Quill Travel
63mm self ejecting
114mm self ejecting
114mm self ejecting
Floor to Spindle Centre
975mm to 1125mm (on optional stand)
1054mm
1130mm
Swing
With optional expansion set
800mm
965mm
Between Centres
1,410mm
1,410mm
Table Saws
High performing reliable machines designed for sustained stability & power
  • Smooth ground tabletop: Durable, low-friction surface
  • Twin mitre fence slots: Accurate and consistent angled cuts to left and right of blade
  • Right, left and rear extension tables: For greater wood handling
  • Fully adjustable T style rip fence: Enables quick and accurate settings with a solid quick lock
  • Hi-Lo sub fence: Two positions, high 80mm and low 10mm
  • Zero clearance throat plate: With fine adjustment screws for precise alignment with the table surface
  • Tool-free spindle lock and a riving knife: For fast blade changes
  • Transparent crown guard: Enhances visibility and waste clearance during operation
F1 Fusion
F3 Fusion
Motor
1.45kW
2.8kW
Blade Diameter / Bore
250mm / 30mm
250mm / 30mm
Minimum Blade Width (Kerf)
3 mm
3 mm
Maximum Depth of Cut @ 90°
79 mm
79 mm
Maximum Depth of Cut @ 45°
56 mm
56 mm
Blade Tilt
45° Left, 3° Right
45° Left, 3° Right
Fence Type
Sliding Cam Action, Fully Adjustable
Rip Capacity (as Standard)
760 mm
910 mm
Rip Capacity (with optional 52” rail)
1,320 mm
Extension Tables (left and right)
Pressed steel
Cast iron
Fence Face Height (Hi/Lo)
80mm / 10mm
80mm / 10mm
Mitre Slot
19mm
19mm
Dust Collection
100mm
100 mm
Cabinet Type
2 piece
Full cabinet
Wheel System
Optional
Built-in
Maximise your investment
Axminster Tools Extended 2-Year Warranty*
Enjoy the confidence of knowing your Laguna machine is backed by Axminster Tools’ exceptional service and care.
*Only available for purchase at the same time as the purchase of your Laguna machine.
Find out more
