The day UJK went electric!
UJK is synonymous with woodwork as Dylan was to folk but there comes the day when Electricity comes calling! Welcome to the stage the UJK Motor and Mount for the UJK Router Lift!
Announcing the launch of UJK's first electric tool! The UJK Motor and Mount for the UJK Router Lift. This innovative addition to the UJK family is set to transform your routing setup with unparalleled power and precision.
The Ultimate Routing Combination
Both packages of the UJK Motor and Mount forgo the need for a traditional router attached to your router table. This new setup offers a seamless and secure attachment, providing consistent performance and convenience.
Which option's for me?
UJK have introduced two packages for the UJK Motor and Mount, both creating a stable, long-term solution for your router table.
The Router Lift Complete Package includes the UJK Motor and Mount, the UJK Router Lift, four ER collets (1/4", 1/2", 8mm, 12mm), and UK and EU plugs.
Everything you need to enhance your router station is included. No need for a traditional router or to own the UJK Router lift, as everything comes in one complete package. You will need a router table—match it with the UJK Router Table and create a full UJK routing set-up!
The UJK Motor and Mount for the Router Lift includes the UJK Motor and Mount, four ER collets (1/4", 1/2", 8mm, 12mm) and both UK and EU plugs.
This set is for those who already own the UJK Router lift. The UJK Motor and Mount seamlessly fit into the UJK Router Lift, creating the perfect setup for your UJK router table and eliminating the need for a traditional router.
UJK Router Lift Complete PackageFrom £699.98 £583.32
Let’s talk power!
At the heart of this setup is the powerful 1800W motor. Featuring variable speed control ranging from 10,000 to 22,000 RPM and a soft-start safety feature. These minimise torque during start-up and maintain a consistent speed under load, ensuring smooth operation and precise routing every time.
Accessible and Accurate
The reason why so many love the UJK Router Lift? For above-the-table height adjustment! This feature makes changing cutters quick and hassle-free, eliminating the need to awkwardly reach under the router table.
Not only that, but each rotation of the handle raises or lowers the cutter by exactly 2mm, with an integral scale graduated into increments for precision adjustments. Plus, turning the handle changes the height by 2mm; the scale allows precise, smaller adjustments suited to your exact needs.
The UJK Router Lift seamlessly fits into many routing setups, perfectly fitting all UJK router tables, and most router tables, accommodating this size of the insert (305 x 229 x 6mm).
Why Choose UJK for routing?
Choosing UJK means investing in quality, innovation, and reliability. UJK designs tools with the woodworker in mind, offering features that enhance your woodworking experience that you didn’t even know you needed. From the powerful motor to the precise height adjustments, every aspect of the UJK Motor and Mount for the Router Lift is designed to deliver exceptional performance. Pair UJK Router Cutters and UJK Accessories with these tools, and your workshop will be set up for success.
Upgrade your UJK Router Lift today and experience the power, precision, and convenience of a dedicated UJK motor.
