Irwin HSS Cobalt Drill Bits
- HSS Colbalt for high wear resistance
- 135° split point grinding for perfect centring
- Ground flute with fast waste removal
- Suitable for stainless steel and other high alloys
- Hard and soft woods, manmade boards and plastics
Axcaliber Ground Tooth Bandsaw BladesFrom £11.98 £9.98 was £11.98 £9.98 Save £0.00 £0.00 -
Axminster Combination Square Metric 300mmSpecial Price £15.20 £12.67 was £17.88 £14.90 Save £2.68 £2.23 -
Axcaliber FineLine PTFE Coated HandsawFrom £12.31 £10.26 was £13.68 £11.40 Save £1.37 £1.14
he Irwin Metric HSS Cobalt Drill Bits are perfect for drilling stainless steel and other high alloys as well as plastics, hard and soft woods and manmade boards. Their 135° split point grinding ensures perfect centring and reduced drilling pressure. An industrial quality ground flute ensures high accuracy drilling and fast removal of chips.
The drill bit body is manufactured from high quality HSS steel containing 5% Cobalt (Co). The added 5% Cobalt improves the red hardness (heat resistance) of the drill bit and results in significantly extended life. It has an attractive golden tempered surface finish.
