Spread the cost of orders up to £30,000 with iwocaPay.
We accept iwocaPay to give business customers more control when it comes to paying. iwocaPay is available for UK Limited Businesses and LLPs on orders of £150 to £30,000.
When you get to the iwocaPay checkout you'll see two choices:
Pay Now in just a few clicks, you can scan a code to pay us straight from your bank account.
Pay Later you'll be able to set up a payment plan with iwocaPay to split the cost with Pay in 3 (Interest Free) or Pay in 12 (3.33% Interest Rate Per 30 Days) equal monthly payments.
Superior design at a great size
A top tier floor drill with advanced design and safety features that set it apart from competition. Â
Buy with confidence
Genuine NSK Ball Bearings
The spindle runs in genuine NSK ball bearings – known for their premium quality. The result is accurate drilling and low vibration, enhancing the overall precision of your work.
Enhanced Safety System
The electronically interlocked chuck guard and integrated belt cover safety switch prevent the machine from being accidentally turned on or running with the cover open, ensuring maximum safety.
Multi-Vee Belts
Multi-vee type belts provide maximum grip and low vibration, contributing to the drill's overall smooth and stable performance.
Improved Depth Stop
The improved depth stop allows for easy adjustment, enabling precise control over drilling depth for consistent results.
Polished Cast Iron Table
The (290 mm x 290 mm / 345 mm x 345 mm / 475 mm x 425 mm*) cast iron table provides a strong and rigid work surface, ensuring stability and durability during drilling operations.
Rack and Pinion Table Adjustment
The rack and pinion mechanism provides quick and easy table adjustments, making it simple to position your workpiece accurately.
One-Piece Cast Iron Handle
With soft rubber grips, the cast iron handle is comfortable to use, reducing user fatigue during extended use
The Axminster Professional AP25FD Floor Drill is designed to provide a robust and precise drilling experience. Featuring a large cast iron table with a polished finish, it offers a strong and rigid work surface, ensuring stability during use. The spindle runs in genuine NSK ball bearings, which both increases accuracy and minimises vibration – both desirable benefits from a drill. The multi-vee type belts provide maximum grip and low vibration, contributing to an even smoother operation.
Safety is a priority with the AP25FD. The electrically interlocked chuck guard prevents accidental activation, and an integrated belt cover safety switch stops the drill from running when the cover is open. The drill also features an adjustable LED work lamp for enhanced visibility of your workpiece.
With the improved depth stop design, you can make easy adjustments for precise drilling depths. Drill control is smooth and comfortable with the one-piece cast iron handle with soft runner grips. The quality 1-16mm keyless chuck allows for quick and easy changing of drill bits, while the rack and pinion table adjustment ensures seamless table adjustments.
The advantages of a floor standing drill are often overlooked; the Axminster Professional AP25FD won’t take up your valuable bench space, which may be at a premium in your workshop.
Please note, if you require an EU plug, please ensure you purchase 113504
Look for the icon and put your trust in Axminster Tools. You’ll get our comprehensive 3-year guarantee on all Axminster Professional machines, which includes:
Year 1 – complete machinery coverage (excluding blades, abrasives, belts, filters/bags, other consumables).
Machine Classification
These products are designed for frequent and extended use in professional environments, offering the performance and durability required for trade and workshop applications, without being intended for full scale professional or continuous use. They must be maintained and serviced annually. Guarantee is void when used for industrial use or part of a production line.
This product is classified as a Large Delivery
product and will normally be delivered within 3-5 working days.
This is a Two-Person Large Delivery service. A two-person carrier
dedicated to delivering larger and heavier consumer goods into your room of choice;
whether in the home (including garden and garage) or at a business address.
The carrier will inform you of your delivery options.
UK Mainland - £70
UK Remote & Offshore* - charge advised in basket
