Bosch Ultra Thin Metal Cutting Discs
- Ultra thin, power saving discs
- Metal fast cutting, suitable for stainless steel
- 230mm (1.9mm thick) diameter
- 230mm max 6,650rpm cutting speed
- For cutting all ferrous metals at far greater speeds
Ultra thin metal cutting discs in 230mm diameters which cut faster than conventional discs by virtue of their reduced thickness. The amount of removed metal is reduced, increasing cutting speed and reducing the heat generated. Particularly suitable for stainless steel. Recommended maximum cutting speed is 6,650rpm for 230mm grinders. The 230mm discs are 1.9mm thick.
| Bore Size | 22 mm |
Please note, respiratory items cannot be accepted for a refund once the seal is broken and the item has been worn.
