DeWALT DCS777T2 XR FLEXVOLT Mitre Saw 2 x 54V Batteries
Spread the cost of orders up to £30,000 with iwocaPay.
We accept iwocaPay to give business customers more control when it comes to paying. iwocaPay is available for UK Limited Businesses and LLPs on orders of £150 to £30,000.
When you get to the iwocaPay checkout you'll see two choices:
- Pay Now in just a few clicks, you can scan a code to pay us straight from your bank account.
- Pay Later you'll be able to set up a payment plan with iwocaPay to split the cost with Pay in 3 (Interest Free) or Pay in 12 (3.33% Interest Rate Per 30 Days) equal monthly payments.
- Online exclusive
- Long life, maintenance free brushless motor
- Integrated positive mitre stops (left and right)
- Twin internal rails, large cutting capacity, compact for transport
- Up to 48° bevel cuts
- Machined base and fence guarantees consistent accuracy
- XPS Shadow Line cut system for accurate, repeatable alignment
- LED light improves sighting even on bright days
- Dust extraction port, DeWALT Airlock compatible
- Supplied with 2 x 54V batteries and charger
Axminster 7 Piece Forstner Bit SetSpecial Price £25.48 £21.23 was £29.98 £24.98 Save £4.50 £3.75 -
Axcaliber Ground Tooth Bandsaw BladesFrom £11.98 £9.98 was £11.98 £9.98 Save £0.00 £0.00 -
Axminster Combination Square Metric 300mmSpecial Price £15.20 £12.67 was £17.88 £14.90 Save £2.68 £2.23 -
Axcaliber FineLine PTFE Coated HandsawFrom £12.31 £10.26 was £13.68 £11.40 Save £1.37 £1.14
DeWALT XR FLEXVOLT is a range of 54V cordless power tools offering unrivalled run time and performance. For the first time, professional trades can reliably undertake heavy-duty construction applications without the need for mains power.
The DCS777T2 XR FLEXVOLT mitre saw provides you with all the performance of a mains powered saw in a highly portable, cordless power tool. The base is the chassis of the successful DWS777 mains mitre saw. This 54V FLEXVOLT cordless version gives you all the benefits of a mains powered saw with the freedom of a cordless tool. You will never need to lug cables, extension leads or other mains related stuff around on or off site again.
The brushless motor gives you a long and maintenance free service life. The well machined base and fence ensure consistent accuracy. The base has integrated positive stops at 15, 22.5, 30 and 45 with a maximum mitre capability of 50° both left and right. The sliding left hand fence has a measuring scale for improved material support and management. The head runs on twin rails ensuring rigidity. The rails run internally giving a large cutting capacity, at the same time making a very compact unit for easy transportation. You can lock the head to restrict the traverse movement when repeat cutting smaller work.
A built-in LED work light illuminates the workpiece for improved sighting even in bright conditions. DeWALT XPS Shadow Line cut technology provides a clear-cut indicator for fast and accurate blade alignment. The dust extraction port is DeWALT Airlock compatible.
The DCS777T2 comes fitted with a 216mm TCT blade giving you a cross cutting capacity of 270mm x 62mm, supplied with 2 x 54V batteries and charger.
The XR FLEXVOLT battery is completely compatible with all existing DeWALT XR 18V products. It offers you an unprecedented 6.0Ah of power in any XR 18V cordless tool.
The product must be registered by the original DeWALT Product user within 4 Weeks of Purchase by visiting the DeWALT website (DeWALT Product user contact details, tool catalogue number, serial number and date code required). Kits comprising a range of tools are excluded from registration, but individual tools from kits must be registered.
All Warranty claims are handled directly with manufacturer please refer to the warranty information supplied on registration for correct procedure.
For full terms and conditions click here.
In order to make a claim, you will need to submit proof of purchase to us or an authorised DeWALT repair agent, and the product must display the CE mark.
*Some products are excluded from the 3 year guarantee. A detailed summary of individual product guarantees is available on the DeWALT website.
| Batteries Included | 2 |
| Battery Capacity | 6.0 Ah |
| Battery Type | Li-ion |
| Battery Voltage | 54 V & 18 V |
| Bevel Angle Range | 0° - 48° |
| Blade Diameter | 216 mm |
| Blade RPM | 6,300 rpm |
| Bore Size | 30 mm |
| Charge Time | 60 minutes |
| EAN Barcode | 5054905003050 |
| Max Bevel Cut @ 45º W x H | 270 mm x 48 mm |
| Max Compound Cut @ 45º W x H | 190 mm x 48 mm |
| Max Crosscut @ 0º W x H | 270 mm x 62 mm |
| Max Mitre Cut @ 45º W x H | 173 mm x 62 mm |
| Mitre Angle Range | 50° - 0 - 50° |
| Model | DCS777T2 |
| Nett Weight | 14 kg |
| Sound Power Level LwA [Uncertainty K] | 104 dB(A) [3.9 dB] |
| Sound Pressure Level LpA [Uncertainty K] | 93 dB(A) [3.0 dB] |
| Spindle Lock | Standard Feature |
| Vibration Cutting Wood [Uncertainty K] | 2.1 m/s² [1.5 m/s²] |
- Standard Delivery* - Free
