Fuji Spray 5432 2-Quart Pressure Pot Assembly Kit
101564
From £319.98 £266.65
  5. Half Star
10 Reviews
Low Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery by Saturday 6th Jun
  • Increases material capacity for longer spraying without refills
  • 2.25L capacity, spray larger areas without refilling
  • Less weight, spraying is less tiring for your arm and wrist
  • Compact gun profile improves access to tight spaces
  • Spray at any angle, even upside down
  • Consistent, pressurised material flow for professional results
  • Ideal for larger finishing and production tasks
  • Requires 25ft standard hose plus a 2049F Whip Hose
The Fuji Spray 2‑Quart Pressure Pot Assembly Kit is designed to increase spraying efficiency by providing a higher‑capacity, lightweight material supply when used with compatible Fuji Spray HVLP turbine systems. By moving the material away from the spray gun, it significantly reduces hand and wrist fatigue while allowing longer, uninterrupted spraying sessions.
With a generous 2.25‑litre capacity, the pressure pot holds approximately twice the material of a standard bottom‑feed spray gun and over three times that of a gravity‑feed cup. This makes it ideal for spraying larger areas such as cabinetry, furniture, doors, or panels without frequent refilling.
The compact pressure pot design allows the spray gun to remain smaller and more manoeuvrable, making it easier to access tight spaces and spray at any angle, including upside down. Material flow remains consistent and stable throughout use, contributing to a smooth, professional finish across a wide range of applications.
Designed for use with 4‑stage Fuji Spray HVLP turbine systems, the 2QT Pressure Pot Assembly eliminates the need for a bulky external compressor when used with compatible equipment.
What’s Included
2‑Quart pressure pot with adaptor
1,800mm material fluid hose
Quick‑connect coupler
Pressure tube and check valve
Nipple caps
Important Usage Information
To use the 2QT Pressure Pot Assembly Kit, a 25ft standard air hose and a 2049F whip hose are required (not supplied).
When used with the 9600‑G GXPC Spray Gun, a 9060 L‑Fitting (Order Code 103702) is also required.
For increased mobility and hands‑free operation, the Fuji Spray 2QT Pressure Pot Backpack (SKU 113002, sold separately) can be used with this assembly kit. When paired together, they create a fully mobile pressure‑pot spraying solution ideal for onsite work, large projects, and extended spraying sessions with improved freedom of movement.
Warranty 2 Year Warranty
Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBirthday CakeA birthday cake with a candleBritish MadeBritish Made logoBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesChristmasChristmasClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsDelivery QuickA clock faceCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramiwocaPayiwocaPay payment logoLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherNotificationA notification bellPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPal CreditPayPal credit payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPound SignA pound currency sign in a circlePreviewAn eye symbolPrinterA printer, printing a piece of paperPrivatePadlockRating Star EmptyEmpty rating starFull Rating StarFull rating starRating Star HalfHalf rating starRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSign InSign In to your accountSign OutSign Out of your accountSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStarA Star symbolStarA Star symbolStockA circle which is coloured to show the current stock levelTagA clothing label tagTeachableThe Logo for TeachableTickA tick symbolDeleteDeleteUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
4.5 10
