Hermes RB 377 YX Abrasive Belts 150 x 1,220mm
- Polyester/cotton cloth backed aluminium oxide abrasive
- High stock removal rates in the coarse grit range
- Consistent surface quality in the fine grit range
To fit Axminster AS609, AS610, AS612, CCBDS69 and most other 6" x 9" belt and disc sanders. The polyester/cotton back combined with the resin bonded aluminium oxide grain mix produces a high stock removal with coarse grits, plus a consistent surface quality with fine grits. Smooth running and long lasting, perfect for abrading metals and sanding seasoned woods.
| Abrasive Backing | Cloth |
| Abrasive Belt Length | 1,220 mm |
| Abrasive Belt Width | 150 mm |
| Abrasive Material | Aluminium Oxide |
| Abrasive Type | RB 377 YX |
