Hermes BW 110 Resin Bonded Abrasive Roll 90mm x 10m
- Aluminium oxide abrasive on heavy E-weight paper backing
- Semi-open coating, anti-static resin bonded reduces clogging
- Economical sanding for excellent results on all types of wood
Aluminium oxide resin bonded abrasive on a heavy weight paper for machine and hand sanding of wood, wood based products, paints and varnishes. The heavyweight paper reduces breakage at the securing point on orbital sanders.
| Abrasive Backing | Paper |
| Abrasive Material | Aluminium Oxide |
| Abrasive Roll Length | 10 m |
| Abrasive Roll Width | 90 mm |
| Abrasive Type | BW 110 |
