Vic Tesolin | An Independent UJK Review
We asked renowned Canadian woodworker, Vic Tesolin, what he thought of the UJK range and the tools he relies on every day in his workshop.
A bit about Vic...
Vic Tesolin is a Canadian woodworker and teacher, alongside his partner Andrea, with a passion for woodworking and education. Vic runs successful social channels inspiring many woodworkers, not just across Canada, but worldwide. His honest, relatable approach to teaching and product reviews are one of many reasons his followers are continuing to grow in numbers. We spoke to Vic about UJK and asked him for his independent opinion.
Having tested many of our UJK products, we asked Vic what his favourite tools from the range would be, and why. Here's what Vic said:
I don’t use a table saw in my shop. Instead, I use a track saw and router setup to do the work of the table saw. The Parf line of tools from UJK simplify my workflow and all but guarantee accurate work. I also use the UJK Parf tools for my hand tool operations. The positioning and work holding features these modern systems offer suit my work better than 300 year old options.
I really like anything that is MFT related that UJK does. The workbench frames are amazing and allow you to make a sturdier work surface compared to the original MFT undercarriage. I’ve yet to find fault with any of the UJK products I have in the shop. They are well-designed and allow me to work the way I like to work.
Vic Tesolin
A selection of Vic's favourite UJK tools...
UJK Parf Mk II Guide System
Winner of the King’s Award for Enterprise 2023, this is a perfectly accurate system. It allows you to create a portable workstation, custom MFT (multifunction table) or portable cutting board in under 30 minutes.
UJK Work Holding Accessory Kit In T-LOC Case
Pairs perfectly with the UJK Parf Guide Systems, this kit allows you easily cut and clamp on your MFT style bench or worktop.
UJK Assembly Square
Made from thick HDF Valchromat, hold parts at exact right angles with this useful square.
UJK Compact Multifunction Workbench
Allows you to work on a quality surface, wherever you are. Small enough to be stored conveniently under a permanent bench or transported to site, the versatile design provides a generous working area.
UJK Hold Down Clamp
Compatible with the UJK T-Track, these clamps can be used in a variety of workshop situations.
UJK Super Dog Accessory Kit in T-Loc Case
Including 22 invaluable UJK accessories. The perfect UJK accessory set.
UJK Expanding 20mm Dog Set
For use in benches and tables with 20mm holes, simply twist the dogs to lock into place.
Featured in this blog
UJK Parf Mk II Guide SystemFrom £199.98 £166.65
UJK Work Holding Accessory Kit In T-LOC CaseFrom £199.98 £166.65
UJK Assembly SquareFrom £32.28 £26.90
UJK Compact Multifunction WorkbenchFrom £246.28 £205.23
UJK Hold Down Clamp 75mmFrom £11.58 £9.65
UJK Super Dog Accessory Kit In T-Loc CaseFrom £289.98 £241.65
UJK Expanding 20mm Dog SetFrom £134.98 £112.48
Want to know more?
Why not explore Vic Tesolin's YouTube or Instagram accounts for more helpful tricks and tips? We think you'll be hooked on his advice in no time!
Discover more...
If you've enjoyed reading this article, we have plenty more which might be of interest to you. Since 1981, Axminster Tools has proudly developed and manufactured a wide range of tools on site here in Devon. We recommend reading the UJK Parf Mk II Guide System write up, or why not check out reviews from Ron Paulk or Badger Workshop?
