Mirka Abranet Ace HD Abrasive Discs 150mm
- Aluminium oxide with ceramic grains
- Heavy-duty, long lasting, fast stock removal
- Strong net backing with hook and loop backing
- Open mesh design eliminates clogging
- Dust-free sanding when used with extraction
- Supplied in packs of 25
Abranet Ace HD has a strong net structure for greater resistance to high wear and tear. The abrasive composition of aluminium oxide with ceramic grain provides you with rapid stock removal and a much increased abrasive lifetime. The net structure delivers dust-free sanding when used with a suitable vacuum extractor.
Abranet Ace HD is suitable for stripping old paint or lacquer, sanding composites, scratch resistant coatings and high VOC coatings and body filler. It is just as effective on bare hardwoods such as oak and beech. This heavy-duty, long lasting abrasive saves time and money. Supplied in packs of 25. We recommend the use of a pad saver for prolonged pad life.
| Abrasive Backing | Mesh and Hook and loop |
| Abrasive Disc Diameter | 150 mm |
| Abrasive Material | Aluminium Oxide, Ceramic |
| Abrasive Type | Abranet Ace HD |
