Scan Moulded Respirator Masks (Pkt 10)
- Online exclusive
- FFP2/FFP3 masks offer high-level protection against fine particles and mists
- Comfortable design with elastic straps, nose clip, and soft lining
- Valve eases breathing for longer wear
- Suitable for sanding, painting, insulation, and metalwork
- EN149 certified, single-use, box of 10
These high-performance disposable masks are engineered to fully cover the nose, mouth, and chin, delivering advanced respiratory protection. Constructed entirely from high-grade filter material, each mask features a built-in exhalation valve to reduce breathing resistance, enhancing comfort during prolonged use. They’ve passed the optional Dolomite clogging test, ensuring optimal airflow and extended performance.
Features:
Elasticated retaining straps for secure fit
Adjustable nose clip and soft foam nose piece for comfort
Full PVC face seal (FFP3) for airtight protection
Non-irritating inner lining
Single-use; dispose after each work period or 8-hour shift
Supplied in boxes of 10
Conforms to EN149:2001+A1:2009 standards
Applications:
Ideal for use in demanding environments, including:
Metal casting
Exposure to smoke and chemical fumes
Painting, varnishing, and welding
Sanding of softwood, hardwood, and MDF
Masonry and concrete dust
Metalworking with power tools
Loft insulation, fibreglass, mineral fibres, and silica dust
Protection Levels:
FFP1: Filters particles >5 microns (dusts, fumes, aqueous/oil-based mists)
FFP2: Filters particles 2–5 microns (fine dusts, fibres, mists)
FFP3: Filters particles <2 microns (very fine dusts, fibres, mists)
Please note, respiratory items cannot be accepted for a refund once the seal is broken and the item has been worn.
