UJK Hex Shank Drill Bit Adaptor
- Converts standard drill bits to quick-change hex shank bits
- A high-performance, low-cost alternative
- Compatible with Festool CENTROTEC
- Precision stainless steel construction for minimal runout
- Ideal for use UJK M2 HSS Premium Brad Point Drill Bits
- Quick change with a secure grip
- Sizes 2, 2.5, 3, 3.5, 4, 4.5, 5, 6, 8, and 10mm
UJK Long Series M2 HSS Premium Brad Point Drill Bit - 8mmFrom £26.18 £21.82 -
UJK StepPower HSCO Drill Bit Set 19 PieceFrom £141.58 £117.98
Transform your standard drill bits into quick-change hex shank bits with the UJK Hex Shank Drill Bit Adaptor. Round shank drill bits, burrs, abrasive points can be easily changed into "quick change" tools with these adaptors, standard 1/4" hex & Festool CENTROTEC compatible.
Designed to give your more flexibility and efficiency, these adaptors are ideal for woodworkers who demand high performance and versatility. Available in sizes 2, 2.5, 3, 3.5, 4, 4.5, 5, 6, 8, and 10mm, these precision-machined adaptors offer a cost-effective alternative to hex shank bits, many of which are difficult to resharpen once damaged. Perfectly matched for use with UJK M2 HSS Premium Brad Point Drill Bits and compatible with Festool CENTROTEC systems. Manufactured from stainless steel to an ultra-high tolerance, ensuring a precise fit and minimal runout. Each adaptor allows for quick changes and has a secure grip.
Available in sizes 2, 2.5, 3, 3.5, 4, 4.5, 5, 6, 8, and 10mm.
