Axcaliber Contract 190mm TCT Saw Blades
- Generously sized tips brazed onto tensioned quality steel plates
- Covering rip to crosscut
- 24, 40 & 56T
- 2.2mm kerf , 1.6mm plate
- 30mm bore
- For larger hand held circular saws
The Axcaliber range of Contract TCT (Tungsten Carbide Tipped) circular saw blades offers an unmatched blend of choice, cutting performance and price.
Manufactured in one of the most advanced facilities in the world, they are produced to the highest standards using the finest materials available. With the range covering everything from hand held power tools right up to large panel saws used in production workshops, you will be certain to find
a blade to suit every requirement. 30mm bore. For all other blades please refer to the Woodworking Machinery section.
| Blade Diameter | 190 mm |
| Bore Size | 30 mm |
| Kerf | 2.2 mm |
| Maximum RPM | 9,000 rpm |
| Plate Thickness | 1.6 mm |
| Tooth Format | ATB |
