Axcaliber Four Flute Tenon/Milling Cutter Long Shank 1/2"
- 50mm TCT cutter for tenons or flattening
- 4-flutes (2 x down-shear, 2 x up-shear) for clean finish
- Long shank for use in router table or Trend RS/JIG
This is a four-flute, 50mm diameter TCT router cutter for cutting tenons or flattening a slab of timber with repeated cuts. It has a 20mm cutting depth. Two of the cutting edges are down-shear blades for the shoulder and the other two up-shear for a clean face to the tenon. This cutter is designed for tenoning where a large area needs to be recessed or for surface flattening. It has a 58mm long shank for improved reach when used in a router table.
Shank diameter 1/2", overall Length: 78mm, maximum speed 18,000rpm.
Note: This is a large cutter for use in a router table or the Trend RS/JIG Router Surfacing Jig only.
| D = Overall Diameter | 50 mm |
| EAN Barcode | 5052511124350 |
| Shank Diameter | 1/2" (12.7 mm) |
| X = Depth of Cut | 20 mm |
- Standard Delivery* - Free
