Axcaliber Milling Cutter
- Axcaliber milling cutter
- 1.1/4"(31.7mm) diameter with 1/2"(12.7mm) depth of cut
- PTFE coating helps minimise resin build-up
- 1/2" shank only
Axminster 7 Piece Forstner Bit SetSpecial Price £25.48 £21.23 was £29.98 £24.98 Save £4.50 £3.75 -
Axminster Combination Square Metric 300mmSpecial Price £15.20 £12.67 was £17.88 £14.90 Save £2.68 £2.23 -
Axcaliber FineLine PTFE Coated HandsawFrom £12.31 £10.26 was £13.68 £11.40 Save £1.37 £1.14 -
The Axcaliber milling cutter is the perfect bit for sign making or any kind of recessed work.
| D = Overall Diameter | 31.75 mm (1.1/4") |
| EAN Barcode | 5052511054053 |
| Shank Diameter | 1/2" (12.7 mm) |
| X = Depth of Cut | 12.7 mm (1/2") |
- Standard Delivery* - £5
