Axcaliber Diamond Saw Blade PCD - 160mm x 2.4mm x 20mm 4T
- Ultra hard, ultra tough polycrystalline diamond (PCD) tips
- Offers high performance and high wear resistance
- Up 20 times lifespan of comparable TCT blades
- Effortless cuts in fibre-cement weatherboards and similar abrasive materials
- Excellent performance in gypsum impregnated chipboard, MDF plywood
- Resin filled slots for noise reduction
- Precision EDM grinding of tips
- Large gullet for rapid waste removal and increased feed speed
Bosch GWS 12V-76 EC Mini Grinder 12V (Body Only)Special Price £117.98 £98.32 was £129.98 £108.32 Save £12.00 £10.00 -
Axcaliber Ground Tooth Bandsaw BladesFrom £11.98 £9.98 was £11.98 £9.98 Save £0.00 £0.00 -
Axminster Combination Square Metric 300mmSpecial Price £15.20 £12.67 was £17.88 £14.90 Save £2.68 £2.23 -
Axminster 7 Piece Forstner Bit SetSpecial Price £25.48 £21.23 was £29.98 £24.98 Save £4.50 £3.75 -
JSP SpringFit™ Fold Flat Valved Respirator FFP2 (Pkt 10)Special Price £16.45 £13.71 was £18.28 £15.23 Save £1.83 £1.52 -
Axcaliber FineLine PTFE Coated HandsawFrom £12.31 £10.26 was £13.68 £11.40 Save £1.37 £1.14
Axcaliber PCD Diamond Saw Blades are suitable for handheld circular saws, mitre saws and saw benches.
The cutting teeth of polycrystalline diamond (PCD) are far harder with up to 20 times the life of a comparable TCT blade, therefore PCD makes excellent economic sense for professional trade use. Ideal for the construction trade, they will effortlessly cut through fibre cement and cutting gypsum or cement impregnated boards. Perfect for cutting fibre cement boards and cladding such as "Hardiebacker, HardyPlank board", "Marley Eternit, Cedral Lap board", "Cembrit", "Minerit" etc and compressed concrete panels.
All blades feature resin filled expansion slots to reduce noise while the extra large gullet design improves the waste removal rate, for increased feed speed. Dust extraction is recommended when using these blades.
| Blade Diameter | 160 mm |
| Bore Size | 20 mm |
| EAN Barcode | 5052511107223 |
| Hook Angle | 12° |
| Kerf | 2.4 mm |
| Maximum RPM | 8,000 rpm |
| Plate Thickness | 1.6 mm |
| Teeth | 4 |
| Tooth Format | F |
- Standard Delivery* - £5
