Axminster 250/254mm Crown Guard
- Suitable for circular saw blades 250/254mm (10")
- Allows extraction from above the blade
- Improves workshop environment
- Fitted with a 63mm outlet
- Will fit most machines that have a suitable riving knife
- Quick and easy single bolt fitting
Axcaliber Premium TCT Saw Blade - 254mm x 3.2mm x 30mm 40TSpecial Price £41.54 £34.62 was £48.88 £40.73 Save £7.34 £6.12 -
Axminster Extraction Hose Kit - 63mm x 2mSpecial Price £31.98 £26.65 was £45.58 £37.98 Save £13.60 £11.33
This Crown Guard is suitable for blades of 250/254mm (10"). It has a single bolt fixing and will fit on the riving knife of most circular saws. The guard has a 63mm extraction outlet at the rear allowing you to connect a dust extractor. Assuming the saw already has an outlet below the blade, the extra point of extraction makes for a much cleaner and safer working environment.
| EAN Barcode | 5052511119547 |
- Standard Delivery* - £5
Please note, respiratory items cannot be accepted for a refund once the seal is broken and the item has been worn.
