Axminster Engineer Series SC4 Floor Standing Lathe
Spread the cost of orders up to £30,000 with iwocaPay.
We accept iwocaPay to give business customers more control when it comes to paying. iwocaPay is available for UK Limited Businesses and LLPs on orders of £150 to £30,000.
When you get to the iwocaPay checkout you'll see two choices:
- Pay Now in just a few clicks, you can scan a code to pay us straight from your bank account.
- Pay Later you'll be able to set up a payment plan with iwocaPay to split the cost with Pay in 3 (Interest Free) or Pay in 12 (3.33% Interest Rate Per 30 Days) equal monthly payments.
- Axminster Engineer Series SC4 Bench Lathe
- High quality lathe suitable for workshop or school use
- Electronically variable spindle speed range of 125-2,000rpm
- 1,000W high torque, brushless motor gives near silent running
- Metric and imperial thread cutting, simple change wheel setting
- Full range of accessories available, tooling, steadies etc.
- Axminster Engineer Series SC4 Floor Stand
- Floor stand for the Axminster Engineer Series SC4 lathe
- Made from welded steel, incorporating two storage cupboards
- This stand complements the lathe very nicely
- Includes drip tray
- Show More
Axminster Engineer Series SC4 Clamp KitFrom £20.88 £17.40 -
Axminster Engineer Series QCTP Standard Tool Holder for SC4From £22.98 £19.15 -
Axminster Engineer Series Quick Change Tool Post Set for SC4From £110.48 £92.07 -
Axcaliber Ground Tooth Bandsaw BladesFrom £11.98 £9.98 was £11.98 £9.98 Save £0.00 £0.00 -
Axminster Combination Square Metric 300mmSpecial Price £15.20 £12.67 was £17.88 £14.90 Save £2.68 £2.23 -
Axminster 7 Piece Forstner Bit SetSpecial Price £25.48 £21.23 was £29.98 £24.98 Save £4.50 £3.75
Package deal comprises Axminster Engineer Series SC4 Bench Lathe and Engineer Series SC4 Floor Stand.
This compact lathe of very modern design has many convenient facilities ideal for the enthusiastic model engineer, small component manufacturer or in a teaching environment. A very rigid induction hardened cast iron bed with ground slideways gives a high level of precision. The lathe has 510mm between centres, with a 210mm swing over the bed. This model has a 1,000W brushless DC high torque motor giving near silent running. A standard feature is the full electronic speed control with digital readout of spindle speed, accessed by a push button control panel. Included, as standard, are a 4-way indexing tool post with 10mm tool shank capacity, transverse adjustment on the tailstock for taper turning, rear splash guard and a 100mm 3-jaw chuck.
This is the floor stand for the Axminster Engineer Series SC4 lathe. Made from welded steel and incorporating two storage cupboards, this stand complements the lathe very nicely. With just the rear panel to assemble, this stand is nice and easy to put together. Includes drip tray.
Axminster Engineer 3 Year Guarantee
Look for the icon and put your trust in Axminster Tools. You’ll get our comprehensive 3-year guarantee on all Axminster Engineer machines, which includes:
Year 1 – complete machinery coverage (excluding blades, abrasives, belts, filters/bags, other consumables).
Machine Classification
These products are designed and intended to be used for regular or frequent use (depending on rating), without being intended for full scale industrial or continuous use. They must be maintained and serviced annually. Guarantee is void when used for industrial use or part of a production line.
Learn more| Centre Height | 105 mm |
| Chuck Fitting | Flange Mounted |
| Cross Slide Travel | 100 mm |
| Distance Between Centres | 510 mm |
| EAN Barcode | 5052511110933 |
| Headstock Taper | 3 MT |
| Leadscrew Pitch | 2 mm |
| Max Diameter over Bed | 210 mm |
| Model | SC4 |
| Nett Weight | 125 kg |
| Overall L x W x H | 1,000 mm x 550 mm x 400 mm |
| Power | 1.0 kW |
| Rating | Engineer |
| Spindle Bore | 20 mm |
| Spindle Speed | 100 - 2,000 rpm |
| Tailstock Taper | 2 MT |
| Thread Pitch Range | 0.25 mm - 3.0 mm / 8 tpi - 24 tpi |
| Tool Shank Size | 10 mm |
| Top Slide Travel | 70 mm |
| Voltage | 230 V |
- UK Mainland - £70
- UK Remote & Offshore* - charge advised in basket
