Axminster Workshop AW118CE Cyclone Dust Extractor - 230V
Spread the cost of orders up to £30,000 with iwocaPay.
We accept iwocaPay to give business customers more control when it comes to paying. iwocaPay is available for UK Limited Businesses and LLPs on orders of £150 to £30,000.
When you get to the iwocaPay checkout you'll see two choices:
- Pay Now in just a few clicks, you can scan a code to pay us straight from your bank account.
- Pay Later you'll be able to set up a payment plan with iwocaPay to split the cost with Pay in 3 (Interest Free) or Pay in 12 (3.33% Interest Rate Per 30 Days) equal monthly payments.
- Compact Cyclone Dust Extractor for home use
- Efficiently separates the wood waste from the airflow
- Use with a variety of machines from thicknessers to sanders
- Airflow: measured in our workshop 1,095m³/hr @125mm
Perfect for a busy home workshop or even a small trade workshop
The AW118CE is a very efficient cyclone extractor. Also referred to as a two stage extractor, the finer dust and larger debris are separated for exceptionally effective extraction.
Protect yourself
Efficiently removing dust at source is the best way to keep your workshop and lungs in tip top condition.
From dust to chips
The AW118CE is suitable for extracting all types of wood waste, from fine dust to larger chips, thanks to the ingenious cyclone design.
Low maintenance
The majority of waste is removed before getting to the filter, requiring less cleaning and infrequent replacement. The filter also has a handy cleaning paddle to remove excess fine dust.
Sturdy yet compact
The AW118CE design is compact yet strong, thanks to its tubular steel frame construction.
Choice of ports
Fitted with twin dust ports, you’re free to choose between twin 100mm inlets or a single 125mm inlet for ultimate flexibility.
Performance
The 1.5kw motor provides plenty of power, whilst running happily on a 13amp plug.
3 Year Guarantee
Axminster Replacement Filter Cartridge for AW118CEFrom £138.10 £115.08 -
The Axminster AW118E cyclone extractor is designed for the enthusiastic home woodworker with features in common with professional models. Compared to other forms of extractors, a cyclone provides a much more efficient performance. The cyclone separates the larger waste particles from the finer dust, before the airflow passes through the extractor’s fan. As a consequence, the fan operates more efficiently maintaining a consistent speed. The heavier waste falls into one bag or container whilst the very fine particles collect in separate receptacle. The cyclone removes the bulk of the waste before it reaches the extractor’s filter. The filter requires cleaning less frequently with far less mess involved.
The AW118E is quite compact, a tubular steel frame supports the cyclone, body, filter and collection bag. The cartridge filter has a manual filter cleaning system. Castors ensure mobility around the workshop. There is a choice of either twin 100mm or a single 125mm inlet. The collection bag is a generous 118-litre and held by a quick release clip. There is a separate collection bag under the filter for fine dust, which in practice, will rarely need emptying. The 1.5kW induction motor provides plenty of performance and runs happily on a domestic 13A supply.
This extractor is efficient, reasonably quiet and very capable. For most home workshops it will be all that you will need.
Airflow: as measured in the Axminster workshop 990m³/hr @100mm and 1,095m³/hr @125mm.
The hose size should not be reduced to less than 75mm, otherwise a marked drop in performance will occur.
Please note, if you require an EU plug, please ensure you purchase 113776
Axminster Workshop 3 Year Guarantee
Look for the icon and put your trust in Axminster Tools. You’ll get our comprehensive 3-year guarantee on all Axminster Workshop machines, which includes:
Year 1 – complete machinery coverage (excluding blades, abrasives, belts, filters/bags, other consumables).
Machine Classification
These products are designed and intended for those who require equipment for more regular, but not continuous, operation. They must be maintained and serviced in line with our schedule; otherwise guarantee may be void.
Learn more| Airflow | 990 m³/hr @ 100 mm (27-34 m/s) / 1,095 m³/hr @ 125 mm (18-24 m/s) |
| Container Volume | 118 litre |
| EAN Barcode | 5052511124947 |
| Filter Performance | 99% >1 micron |
| Hose Diameter | 1 x 125 mm or 2 x 100 mm |
| Model | AW118CE |
| Nett Weight | 64 kg |
| Overall L x W x H | 1,100 mm x 570 mm x 1,785 mm |
| Plug Fitted | UK 3 pin plug |
| Power | 1.5 kW |
| Rating | Regular Use |
| Sound Pressure Level LpA [Uncertainty K] | 77 dB(A) [1.5 dB] |
| Voltage | 230 V |
- Standard Delivery* - Free
