Mitres and bevels made simple
Featuring an impressive cutting capacity, soft start motor, depth stop, laser guide, work light and more, the AW254SMS Slide Mitre Saw makes both home woodworking and light, occasional professional tasks effortless and enjoyable.
Buy with confidence
Soft start motor
The 1.8kW motor drives the 254mm blade at up to 4,500rpm, delivering clean, smooth cuts. The soft start feature ensures controlled start-ups for more comfortable use in home environments, while its overall performance is well suited to a wide range of home and small workshop tasks.
Cutting capacity
The sliding mechanism delivers a maximum crosscut of 305 x 90mm, perfect for larger boards. Its 52° left to 60° right mitre range and 45° left/right bevel capability enable versatile angled, mitre, and compound cuts, with maximum 45° capacities of 215 x 90mm for mitres and 215 x 40mm for bevels.
Trenching
Achieving controlled trenching cuts is easy thanks to the depth stop. This makes it perfect for housing joints and other woodworking applications.
Ultimate accuracy
The mitre saw's laser and light make creating accurate cuts a breeze. The laser creates a precise marking, making it easier to align and visualise your cut.
Secure clamping
Securely hold timber in place using the material clamp to prevent movement and enhance safety.
Portable
The AW254SMS Slide Mitre Saw includes integrated carry handles for easy transport around the workshop.
Quality blade
Supplied with a 60 tooth, negative rake contract quality blade to give excellent control and longevity.
Perfect for...
Perfect for decking, outdoor projects, and precision cutting of trim and mouldings, this versatile tool is an excellent choice for both DIY enthusiasts and professionals tackling occasional jobs.
Not sure which machine is right for your task?
Explore our machinery classification page to compare classification options and ensure you select the best machine for your needs.
