Axminster Workshop AW300DS 300mm Disc Sander - 230V
107672
From £209.98 £174.98
  5. Half Star
50 Reviews
Dispatching Soon
- Email me when available
Delivery
Free Standard Delivery*.
Dispatch estimate is within 3 working days.
  • Quiet 750W induction motor with disc brake and NVR switch
  • Tilting cast iron sanding table with mitre fence
  • Efficient dust extraction, supplied with connector for vaccuum extractor
A strong, versatile disc sander that won’t break the bank!
Perfect for any hobbyist’s workshop, the build quality and performance of this sander really does speak for itself when you see it in use.
Buy with confidence
Strong and sturdy design
The main body is cast iron which helps to reduce vibration for a more comfortable experience.
Plenty of power
A quiet 750W induction motor provides ample power to handle your projects, while a disc brake and NVR switch safeguard you for complete peace of mind at all times.
Sand compounds and mitres
The table incorporates a mitre fence running in a slot, for bevel and compound angle sanding. Both sanding functions use a decent size work table which pivots from 0° to 45°. 
High levels of dust extraction
The disc is fitted with close fitting guarding, to help with efficient extraction for safeguarding health and better visibility whilst working. Plus, almost 100% dust extraction can be achieved when connected to a simple vacuum extractor.
Quiet running
The disc sander is driven by the quiet 750W induction motor, for enjoyable work.
Perfect for…
This sander is ideal for outside curves, sanding to the line, smoothing wood and plastic, removing small waste material and prepping surfaces by removing old finishes.
The AW300DS has an 300mm diameter aluminium disc driven by a quiet 750W induction motor. It has a no-volt-release switch and a brake to slow the disc down in a reasonable time.
The cast iron sanding table has a ground top surface with a slot for the mitre fence. The unique mitre fence has two faces at 90° and can produce LH and RH 45° bevels without resetting. The table tilts up to 45° and firmly locks at both sides.
Efficient dust extraction is via a 63mm outlet. A 450mm length of flexible hose is provided with the machine for connection to a vacuum or similar extractor.
Overall, the AW300DS is solid, weighty and stable and does a good job when it comes to sanding to a line and similar tasks.
Self adhesive abrasive discs are available in a wide range of grits.
Tip: Self adhesive discs can easily be removed complete with their glue by gently warming with a hot air gun (or a simple hair drier) before removing.
Please note: these machines are designed and manufactured for sanding wood and similar materials and should not be used to abrade or grind metal.
Warranty Axminster Workshop 3 Year Guarantee
Look for the icon and put your trust in Axminster Tools. You’ll get our comprehensive 3-year guarantee on all Axminster Workshop machines, which includes:
Year 1 – complete machinery coverage (excluding blades, abrasives, belts, filters/bags, other consumables).
Machine Classification
These products are designed and intended for those who require equipment for more regular, but not continuous, operation. They must be maintained and serviced in line with our schedule; otherwise guarantee may be void.
Learn more
Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBirthday CakeA birthday cake with a candleBritish MadeBritish Made logoBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesChristmasChristmasClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsDelivery QuickA clock faceCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramiwocaPayiwocaPay payment logoLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherNotificationA notification bellPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPalPayPal payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPound SignA pound currency sign in a circlePreviewAn eye symbolPrinterA printer, printing a piece of paperPrivatePadlockRating Star EmptyEmpty rating starFull Rating StarFull rating starRating Star HalfHalf rating starRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSign InSign In to your accountSign OutSign Out of your accountSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStarA Star symbolStarA Star symbolStockA circle which is coloured to show the current stock levelTagA clothing label tagTeachableThe Logo for TeachableTickA tick symbolDeleteDeleteUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
4.42 50
