Bosch GKS 12V-26 Cordless Circular Saw Li-Ion 12V (Body Only)
- Powerful with the freedom to cut almost anywhere
- Cuts 26.5mm at 90° and 17mm at 45°
- Thin kerf 85mm blade (less power needed and less material waste)
- Body only, utilises batteries from other tools in the family
- Fitted with electronic cell protection (ECP) for battery protection
- 3 year warranty available (registration required)
- Supplied with parallel guide and guide rail adapter for Bosch guide rail system
- Supplied as body only with 20 Tooth TCT blade, and dust extraction adapter.
The Bosch 10.8V/12V is perfect for cutting laminate flooring and similar, this compact circular saw gives a powerful cut in wood up to maximum depth of 26.5mm at 90° and 17mm at 45°. The base is adjustable for depth and has an angle scale. The thin kerf TCT blade draws less power from the machine with less waste than a thicker kerf blade to ensure quick progress through the material.
Supplied as a body only so that you can utilise batteries from the other tools in the family. Bosch Li-Ion battery technology is premium quality for the best possible battery life and runtime; tool and battery talk to each other as fitted with electronic cell protection (ECP).
Utilise batteries from the other tools in the family. Bosch Li-Ion battery technology is premium quality for the best possible battery life and runtime; tool and battery talk to each other as they are fitted with electronic cell protection (ECP).
Supplied as body only and Parallel guide/guide rail adapter that can be used to guide the tool or used with a Bosch guide rail.
N.B. Bosch Professional are changing the product name of 10.8V power tools, batteries and chargers to 12V. All Bosch Professional 12V tools are 100% compatible with all current (10.8V) Bosch Professional power tools, batteries and chargers. All 10.8V and 12V tools can be used within the same voltage class system.
This applies to all professional blue power tools and measuring instruments from Bosch. The warranty excludes high-frequency tools, production cordless screwdrivers and pneumatic tools, supplied accessories, battery packs and chargers.
All Warranty claims are handled directly with manufacturer please refer to the warranty information supplied on registration for correct procedure.
Registration required within four weeks of purchase. More information can be found on the Bosch warranty website and in the warranty conditions.
| Batteries Included | Body Only Tool |
| Battery Type | Li-ion |
| Battery Voltage | 12 V |
| Blade Diameter | 85 mm |
| Bore Size | 15 mm |
| Corded or Cordless | Cordless |
| EAN Barcode | 3165140755849 |
| Max Depth of Cut @ 45º | 17 mm |
| Max Depth of Cut @ 90º | 26.5 mm |
| Model | GKS 12V-26 |
| Nett Weight | 1.95 kg |
| Saw Blade Speed | 1,400 rpm |
| Sound Power Level LwA [Uncertainty K] | 101 dB(A) [3.0 dB] |
| Sound Pressure Level LpA [Uncertainty K] | 90 dB(A) [3.0 dB] |
| Spindle Lock | Standard Feature |
| Vibration Cutting Wood [Uncertainty K] | 2.5 m/s² [1.5 m/s²] |
| Warranty Length | 3 Year |
- Standard Delivery* - Free
