Bosch T308BF Jigsaw Blades Tear Free Hardwood (Pkt 5)
- Hardwood and high quality laminate cutting
- Fast clean cutting on both sides of work
- Two rows of different style teeth
- Scalpel tooth and pointed tooth
- BIM longlife blades
- Pack of 5
Clean accurate and tear free on both sides of the hardwood and laminate material. Two rows of teeth arranged at different angles, a razor sharp scalpel tooth will cut the wood fibres on the reverse whilst a precision ground pointed tooth separates the wood fibres on the top surface and give super clean cuts. BIM longlife blades suitable for hard wood and high quality laminate boards.
| Blade Type | Bi-metal, Ground |
| EAN Barcode | 3165140470322 |
| Jigsaw Blade Length | 91 mm |
| Jigsaw Blade Type | Clean Cuts |
| Max Cutting Depth | 20 mm |
| Model | T300BF |
| Pack Quantity | 5 |
| Tooth Pitch \ tpi | 2.20 mm \ 11.5 tpi |
- Standard Delivery* - £5
