DeWALT DWE6423 125mm Random Orbit Sander
- 280W motor with variable speed control
- Uses hook and loop discs; secure and easy change
- Reliable, robust, hard working and durable
- Dust sealed switch and sealed bearings; long working life
- Ergonomic anti-slip grip for comfort and control
- Supplied with dust bag; dust extractor compatible
Flexipads Hand Block for 125mm Hook & Loop DiscsSpecial Price £7.98 £6.65 was £8.98 £7.48 Save £1.00 £0.83 -
Random orbital sanders combine circular sanding discs with simultaneous reciprocal and eccentric circular motions to provide an ultra smooth finish. They eliminate the swirling pattern commonly found (often too late) after using a standard orbital sander. The DeWALT DWE6423 125mm random orbital sander is suitable for home, site or a professional workshop. It is a reliable, robust, hard working and durable machine suitable for a wide range of applications in wood and other materials. The DeWALT DWE6423 has a 280W motor and variable speed control offering speeds between 8,000 to 12,000 orbits per minute. An ergonomic textured anti-slip top and body grips ensures both comfort and control. A dust sealed switch and sealed ball bearings prevent contamination of the internal components, enhancing the tool's durability and working life span. The sander uses hook and loop paper for secure attachment and fast changing. The DWE6423 comes with a cloth dust bag; the dust extraction port is compatible with the DeWALT AirLock system.
The product must be registered by the original DeWALT Product user within 4 Weeks of Purchase by visiting the DeWALT website (DeWALT Product user contact details, tool catalogue number, serial number and date code required). Kits comprising a range of tools are excluded from registration, but individual tools from kits must be registered.
All Warranty claims are handled directly with manufacturer please refer to the warranty information supplied on registration for correct procedure.
For full terms and conditions click here.
In order to make a claim, you will need to submit proof of purchase to us or an authorised DeWALT repair agent, and the product must display the CE mark.
*Some products are excluded from the 3 year guarantee. A detailed summary of individual product guarantees is available on the DeWALT website.
| Corded or Cordless | Corded |
| Dust Collection | Dust Bag Supplied |
| EAN Barcode | 5035048553930 |
| Model | DWE6423 |
| Motor Power | 280 W |
| Nett Weight | 1.28 kg |
| No Load Speed | 8,000 - 12,000 rpm |
| Orbit Diameter | 2.6 mm |
| Pad Size | 125 mm |
| Plug Fitted | UK 3 pin plug |
| Sound Power Level LwA [Uncertainty K] | 91 dB(A) [3.0 dB] |
| Sound Pressure Level LpA [Uncertainty K] | 80 dB(A) [3.0 dB] |
| Vibration Sanding [Uncertainty K] | 2.5 m/s² [1.5 m/s²] |
| Voltage | 230 V |
