Faithfull Pro HSS Long Series Ground Drill Bits
- Professional quality, extra length allows for drilling deep holes
- Ground from M2 HSS steel, 135° non slip point
- Clear the flute periodically whilst drilling to prevent over-heating
- We recommend using lubricant when drilling in ferrous metals
- Sold in packs of 2, 2mm - 6mm and 6.5mm and over in singles
These are professional quality fully ground metric drill bits made from M2 grade high speed steel. With a 135 degree non slip point. The extra length allows for drilling deep holes, but care should be taken to clear the flute periodically whilst drilling to prevent over-heating. Suitable for all wood, metal (alloy Steels, Carbon Steels, Cast Iron, Hardened Alloy Steels, Stainless Steels) and plastic drilling. When drilling in ferrous metals the use of a lubricant is recommended at all times. Meet DIN 338. Sold in packs of 2, 2mm - 6mm and 6.5mm and over in singles.
