Festool CSC SYS 50 EBI-Basic Cordless Table Saw 18V (Body Only)
Spread the cost of orders up to £30,000 with iwocaPay.
We accept iwocaPay to give business customers more control when it comes to paying. iwocaPay is available for UK Limited Businesses and LLPs on orders of £150 to £30,000.
When you get to the iwocaPay checkout you'll see two choices:
- Pay Now in just a few clicks, you can scan a code to pay us straight from your bank account.
- Pay Later you'll be able to set up a payment plan with iwocaPay to split the cost with Pay in 3 (Interest Free) or Pay in 12 (3.33% Interest Rate Per 30 Days) equal monthly payments.
- A table saw in a Systainer; compact for easy transport
- A cordless machine with mains power performance
- Digital display for both blade height and blade tilt
- Set the depth of cut to within 0.1mm
- Set blade angle to within 0.1°
- Low maintenance, powerful EC-TEC motor
- Systainer lid features storage for the fences etc
- Cross cut width at 90° - 450mm
- Parallel rip cut width - 280mm
- Cutting height at 0° - 0 to 48mm
- Blade Tilt -10° to +47°
- Show More
A table saw in Systainer format
Serious sawing, on the go.
Particularly precise
Removes the guesswork. Produces maximum precision down to accuracies within a tenth of a millimetre. With 100% repeatable accuracy, you’ll never miss the mark.
Optimal technology
Keep it simple. Set your desired sawing height and angle at the press of a button, via the digital display and dial. This adjusts the saw blade automatically.
Exceptional capacity
Simply impressive, offering a scope of cuts. From parallel cuts of up to 280 mm, a cross-cut width of up to 450 mm and angled cuts of -2° to 47.
Unparalleled power
Power isn’t compromised in this cordless machine. Even rip cuts in solid wood, the 2x 18V dual battery system with the powerful brushless EC-TEC motor will impress you. Takes Festool 4.0Ah and 5.0Ah Batteries.
Undeniably compact and mobile
So compact it fits into a Systainer, you don’t get more mobile than this. Achieve workshop quality sawing, on the construction site. Simple.
Fast changes
Efficient working. Change the saw blade quickly, without any complications.
Efficient storage
Keep everything to hand. Saw blades, a space wedge and dust collection bag are all securely stored in the lid of the Systainer.
Seamlessly compatible
Simply Festool. Combine your cordless saw with a cordless extractor, it just makes sense.
Festool CTMC MIDI I-Basic Cordless Extractor 18V (Body Only)From £647.98 £539.98 -
Festool Battery & Charger Set 18V (4 x 4.0Ah)From £522.98 £435.82
A table saw in a Systainer, and cordless, and powerful, and accurate, and versatile; the CSC SYS 50 cordless table saw is all of these. The Systainer format makes it easily transportable particularly for mobile professionals. The CSC SYS 50 is fully compatible with the entire Festool Systainer system. This unique saw offers workshop performance on site.
Power comes from two 18V batteries (from 4.0Ah) in combination with a brushless EC-TEC motor, resulting in performance more than comparable to a mains-powered machine. NOTE: this is a body only machine supplied without batteries or charger. The brushless EC-TEC motor with high speeds of 6,800 rpm guarantees fast sawing progress.
The CSC SYS 50 allows you to make parallel rip cuts of up to 280mm wide and cross-cut widths of up to 450mm. The maximum depth of cut is 48mm and the blade tilt; from -10° to 47°.
The outstanding feature has to be the digital display for both blade height and blade tilt. Select the function, then turn the knob to set the depth of cut to within 0.1mm or the blade angle to within 0.1°. Reproducing cuts couldn’t be more accurate, the digital display ensures precise results. Four saw blade positions can be saved and selected via the digital display. The height and angle are electrically adjusted at the press of a button.
On the left hand side the super smooth sliding table and mitre crosscut fence allow cutting up to 450mm in front of the blade and mitre angles from -70° to +70°. On the right hand side a fold down table extension and rip fence allow cuts of up to 280mm wide. The rip fence locks front and back with a single clamping lever.
Supplied with 42 tooth TCT saw blade and chip collection bag. Alternatively, it can be connected to a suitable vacuum dust extractor.
The blade guard and riving knife can be quickly removed for grooving or rebate cuts and just as easily re-installed. The Systainer lid features storage for the fences, blade guard, dust bag and spare blade.
At the end of the day the Systainer hood securely clips in place over the saw, allowing easy transportation and protection.
Table height 228mm
Cross cut width at 45° - 340mm
Cross cut width at 70° - 140mm
Cutting height at 45° - 0 to 34mm
Cutting height at 47° - 0 to 33mm
Cutting height at ‑2° - 0 to 48mm
Cutting height at ‑10° - 21 to 32mm
In order to take advantage of the Festool Warranty All-Inclusive, you will need to create a MyFestool account and register your tool within 30 days of purchase.
Benefits
- Includes 36-month machine guarantee
- Full repair, free of charge
- Replaced in the event of theft*
- Original parts guaranteed
- 14-day money back*
All Warranty claims are handled directly with manufacturer please refer to the warranty information supplied on registration for correct procedure.
Warranty issues outside of the UK - Please refer to the warranty in the home country and if a tool has to be returned to UK be aware that all postage costs would need to be arranged and paid by the customer.
Axminster Tools cannot register a Festool tool on a customer's behalf.
NB: For more information and *full terms and conditions visit the Service section of the Festool website.
Find out more| Batteries Included | Body Only Tool |
| Battery Type | Li-ion |
| Battery Voltage | 36 V (2 x 18 V) |
| Bevel Angle Range | -10° to +47° |
| Blade Diameter | 168 mm |
| Bore Size | 20 mm |
| Corded or Cordless | Cordless |
| Dust Extraction | 27 mm / 36 mm Outlet |
| EAN Barcode | 4014549381694 |
| Kerf | 1.8 mm |
| Manufacturer Part Number | 576820 |
| Max Depth of Cut @ 45º | 34 mm |
| Max Depth of Cut @ 90º | 48 mm |
| Mitre Angle Range | 0° - 70° |
| Model | CSC SYS 50 EBI-Basic |
| Nett Weight | 20.2 kg (without batteries) |
| Overall L x W x H | 512 mm x 396 mm x 296 mm |
| Saw Blade Speed | 4,500 - 6,800 rpm |
| Sound Power Level LwA [Uncertainty K] | 98 dB(A) [3.0 dB] |
| Sound Pressure Level LpA [Uncertainty K] | 85 dB(A) [3.0 dB] |
| Spindle Lock | Standard Feature |
- Standard Delivery* - Free
Please note, respiratory items cannot be accepted for a refund once the seal is broken and the item has been worn.
