Festool CTM 26 EI CLEANTEC Dust Extractor 230V
Spread the cost of orders up to £30,000 with iwocaPay.
We accept iwocaPay to give business customers more control when it comes to paying. iwocaPay is available for UK Limited Businesses and LLPs on orders of £150 to £30,000.
When you get to the iwocaPay checkout you'll see two choices:
- Pay Now in just a few clicks, you can scan a code to pay us straight from your bank account.
- Pay Later you'll be able to set up a payment plan with iwocaPay to split the cost with Pay in 3 (Interest Free) or Pay in 12 (3.33% Interest Rate Per 30 Days) equal monthly payments.
- Wet or dry extraction (wet requires accessory filter)
- High-performance turbine ensures consistent and powerful suction
- Automatic switch-on/off syncs with power tools for maximum efficiency
- Large capacity container captures even the finest dust particles
- Low noise level: Comfortable to use for extended periods.
- Ergonomic design reduces fatigue and increases productivity
- Power Take Off (PTO) synchronises the operation with your power tool
- Works with a wide range of Festool tools and accessories
Festool Self Clean Filter Bags for CTL26/ CTM26 ExtractorsSpecial Price £49.98 £41.65 was £54.98 £45.82 Save £5.00 £4.17 -
Festool Antistatic Hose with Bypass D27/32 - 5mFrom £226.88 £189.07 -
Axcaliber FineLine PTFE Coated HandsawFrom £12.31 £10.26 was £13.68 £11.40 Save £1.37 £1.14 -
Axminster Combination Square Metric 300mmSpecial Price £15.20 £12.67 was £17.88 £14.90 Save £2.68 £2.23 -
Introducing the Festool Mobile Dust Extractor CLEANTEC CTM 26 EI 230V – the ultimate all-rounder for workshops and construction sites. The "M" class CLEANTEC CTM 26 EI 230V filters 99.9% of hazardous dust with limit values greater than 0.1 mg/m³ for a safer, healthy and clean working environment. M class dust extractors are suitable for vacuuming/extracting dry, non-combustible dusts, non-combustible liquids, wood dusts and hazardous dusts with STELs >0.1mg/m³. Suitable for wet or dry extraction (wet requires accessory filter).
This powerful extractor boasts a generous 26-litre container volume while maintaining a compact design, making it perfect for any workspace. With its intuitive touch operation, you can easily control the extractor, even when wearing gloves or working in a dirty environment.
The CLEANTEC CTM 26 EI is equipped with a permanently installed Bluetooth® interface, allowing you to start the extractor using a Festool cordless tool or optional remote control. You can also connect it to the Festool app for seamless integration and support. The smooth, anti-static suction hose can be conveniently stowed away in the integrated hose holder, ensuring a tidy workspace.
The Power Take Off (PTO) feature is a plug socket, found on the wet and dry vacuum cleaner, that synchronises the operation of the vacuum cleaner with your power tool. So, when you switch on the power tool you are using, the vacuum will automatically switch on too.
Thanks to the T-LOC system, you can quickly connect Systainers, pre-separators, or Workcenters, making the extractor the central point of your system. The high-performance turbine ensures constantly high suction power, while the large pivoting rollers and integrated brake provide optimal mobility and stability.
Whether you're dealing with hazardous wood dust or mineral dust, the CLEANTEC CTM 26 EI is approved for dust class M, ensuring a safe and clean working environment. Its robust design and flexible features make it a reliable companion for years to come. Experience the convenience and efficiency of the Festool Mobile Dust Extractor CLEANTEC CTM 26 EI 230V – your go-to solution for clean and efficient work.
Comes with main filter, SELFCLEAN filter bag, and smooth suction hose diameter 27/32 x 3.5 m AS/CTR.
In order to take advantage of the Festool Warranty All-Inclusive, you will need to create a MyFestool account and register your tool within 30 days of purchase.
Benefits
- Includes 36-month machine guarantee
- Full repair, free of charge
- Replaced in the event of theft*
- Original parts guaranteed
- 14-day money back*
All Warranty claims are handled directly with manufacturer please refer to the warranty information supplied on registration for correct procedure.
Warranty issues outside of the UK - Please refer to the warranty in the home country and if a tool has to be returned to UK be aware that all postage costs would need to be arranged and paid by the customer.
Axminster Tools cannot register a Festool tool on a customer's behalf.
NB: For more information and *full terms and conditions visit the Service section of the Festool website.
Find out more| Airflow Volume | 3,900 litre/min |
| Cable Length | 7.5 m |
| Corded or Cordless | Corded |
| EAN Barcode | 4014549431498 |
| Extractor Classification | M Class |
| Manufacturer Part Number | 577920 |
| Max Capacity with Filter Bag | 24 litre |
| Model | CTM 26 EI |
| Nett Weight | 14.6KG |
| Overall L x W x H | 630 x 365 x 540 mm |
| Sound Pressure Level LpA [Uncertainty K] | 71 dB(A) |
| Voltage | 230 V |
- Standard Delivery* - Free
