Festool ETS 150/5-EQ Plus Sander
Spread the cost of orders up to £30,000 with iwocaPay.
We accept iwocaPay to give business customers more control when it comes to paying. iwocaPay is available for UK Limited Businesses and LLPs on orders of £150 to £30,000.
When you get to the iwocaPay checkout you'll see two choices:
- Pay Now in just a few clicks, you can scan a code to pay us straight from your bank account.
- Pay Later you'll be able to set up a payment plan with iwocaPay to split the cost with Pay in 3 (Interest Free) or Pay in 12 (3.33% Interest Rate Per 30 Days) equal monthly payments.
- Very low vibration
- Extended abrasive life with 'MULTI-JETSTREAM 2 pad', reduces heat and prevents clogging
- Low weight 1.8kg
- Plug-it® detachable cable system
- 5mm orbit for fine to intermediate sanding and polishing
- Very efficient dust extraction
- Made for continuous working
- 3 year warranty (excluding sanding pad)
Axminster 7 Piece Forstner Bit SetSpecial Price £25.48 £21.23 was £29.98 £24.98 Save £4.50 £3.75 -
Axminster Combination Square Metric 300mmSpecial Price £15.20 £12.67 was £17.88 £14.90 Save £2.68 £2.23 -
Axcaliber Ground Tooth Bandsaw BladesFrom £11.98 £9.98 was £11.98 £9.98 Save £0.00 £0.00 -
Axcaliber FineLine PTFE Coated HandsawFrom £12.31 £10.26 was £13.68 £11.40 Save £1.37 £1.14
The ETS 150mm sander is eccentric in its action with minimal vibration for excellent working results. With a 5mm orbit it is suitable for intermediate to fine finishing, sanding wood, varnish, paint, fillers and plastic.
You can be assured of a faultless finish with step less speed preselection so you can choose the correct speed to suit the work, constant electronics for consistent speed under load and a sanding pad brake. Fitted with dual bearings that make them very durable and Plug it cable system.
The pad has the patented MULTI-JETSTREAM 2 principle that works using intake air and exhaust air to generate airflow transporting the sanding dust away from the pads surface so that the abrasive wears evenly without clogging as well as keeping the surface at a low temperature. The result is almost 100% dust extraction for an improved rate of material removal, a better finish and a healthy working environment. Made from MPE high tear resistant material the pad is also very durable.
Supplied with MULTI-JETSTREAM 2 sanding base (soft), disposable dust bag and stacking Systainer® T-LOC SYS3 storage case.
In order to take advantage of the Festool Warranty All-Inclusive, you will need to create a MyFestool account and register your tool within 30 days of purchase.
Benefits
- Includes 36-month machine guarantee
- Full repair, free of charge
- Replaced in the event of theft*
- Original parts guaranteed
- 14-day money back*
All Warranty claims are handled directly with manufacturer please refer to the warranty information supplied on registration for correct procedure.
Warranty issues outside of the UK - Please refer to the warranty in the home country and if a tool has to be returned to UK be aware that all postage costs would need to be arranged and paid by the customer.
Axminster Tools cannot register a Festool tool on a customer's behalf.
NB: For more information and *full terms and conditions visit the Service section of the Festool website.
Find out more| Corded or Cordless | Corded |
| Dust Extraction | 27 mm Outlet |
| EAN Barcode | 4014549148938 |
| Manufacturer Part Number | 571917 |
| Model | ETS150/5-EQ |
| Motor Power | 310 W |
| Nett Weight | 1.8 kg |
| No Load Speed | 6,000 - 10,000 rpm |
| Orbit Diameter | 5.0 mm |
| Pad Size | 150 mm |
| Plug Fitted | UK 3 pin plug |
| Sound Power Level LwA [Uncertainty K] | 83 dB(A) [3.0 dB] |
| Sound Pressure Level LpA [Uncertainty K] | 72 dB(A) [3.0 dB] |
| Vibration Sanding [Uncertainty K] | 5.0 m/s² [2.0 m/s²] |
| Voltage | 230 V |
- Standard Delivery* - Free
