Festool KSC 60 EB- Basic Cordless Mitre Saw 18V (Body Only)
Spread the cost of orders up to £30,000 with iwocaPay.
We accept iwocaPay to give business customers more control when it comes to paying. iwocaPay is available for UK Limited Businesses and LLPs on orders of £150 to £30,000.
When you get to the iwocaPay checkout you'll see two choices:
- Pay Now in just a few clicks, you can scan a code to pay us straight from your bank account.
- Pay Later you'll be able to set up a payment plan with iwocaPay to split the cost with Pay in 3 (Interest Free) or Pay in 12 (3.33% Interest Rate Per 30 Days) equal monthly payments.
- Professional quality for high-precision cross cuts
- Highly portable, compact and lightweight design
- 60° mitre L and R with indents for common angles
- 47° L 46° R bevel cutting with 45° stops for easy setup
- Large capacity 305mm crosscut, 60mm depth
- Pull-out extension tables for long workpieces
- Supplied with; dust bag, clamp, additional feet, 36 tooth TCT blade and Bevel SM-KS.
Make unbeatable cross cuts
Combining the flexibility of a battery-powered tool, with the performance of a mains powered machine, the KSC 60 EB is a joy to use. Produce high precision cross cuts with ease, across a whole host of applications.
Limitless mobility
Easily transport this machine, with its ergonomically positioned handles and practical safety device. Manoeuvre it with ease, thanks to its compact, lightweight design and flush-mounted guide rods.
Remarkable versatility
Easily adjust your angles with this versatile machine, thanks to the mitre angle guides of up to 60° on each side. By using the snaps on the table, you can simply select the preset mitre angle via locking positions, for a fast setup.
Axcaliber Ground Tooth Bandsaw BladesFrom £11.98 £9.98 was £11.98 £9.98 Save £0.00 £0.00 -
Axminster 7 Piece Forstner Bit SetSpecial Price £25.48 £21.23 was £29.98 £24.98 Save £4.50 £3.75 -
Axcaliber FineLine PTFE Coated HandsawFrom £12.31 £10.26 was £13.68 £11.40 Save £1.37 £1.14 -
Axminster Combination Square Metric 300mmSpecial Price £15.20 £12.67 was £17.88 £14.90 Save £2.68 £2.23
The Festool KAPEX KSC 60 cordless sliding compound mitre saw combines the freedom of a battery powered tool with the performance of a mains powered machine. The brushless EC-TEC motor coupled with dual 18V battery power can provide enough runtime for a typical full day's work. The KSC 60 produces unbeatable precise crosscuts. Mitre angles of up to 60° on each side with indents at common angles and bevel angles 47° L and 46° R, with stops at 45° for fast setup.
The twin guide bars with two bearings each ensure that the saw blade moves smoothly and precisely at every angle; making every cut perfect. The variable speed can be preset for the best results for the material in use. The low weight, compact design and convenient handles make this easily portable for work on site. An LED spotlight highlights the cutting line ensuring good visibility of a scribed cutting line. A large dust bag is supplied making for a cleaner workspace even without a mobile dust extractor. Pull out extension tables on each side provide support for longer workpieces.
The additional feet bring the height of the KSC 60’s table to the exact same height of an SYS 3 M 112 or SYS 1 Systainer case.
Includes a Festool bevel which transfers interior or exterior angles to the saw for a perfect mitre every time.
Please Note; this is a body only machine supplied without batteries or charger.
Part of the Festool 18V family.
In order to take advantage of the Festool Warranty All-Inclusive, you will need to create a MyFestool account and register your tool within 30 days of purchase.
Benefits
- Includes 36-month machine guarantee
- Full repair, free of charge
- Replaced in the event of theft*
- Original parts guaranteed
- 14-day money back*
All Warranty claims are handled directly with manufacturer please refer to the warranty information supplied on registration for correct procedure.
Warranty issues outside of the UK - Please refer to the warranty in the home country and if a tool has to be returned to UK be aware that all postage costs would need to be arranged and paid by the customer.
Axminster Tools cannot register a Festool tool on a customer's behalf.
NB: For more information and *full terms and conditions visit the Service section of the Festool website.
Find out more| Batteries Included | Body Only Tool |
| Battery Type | Li-ion |
| Battery Voltage | 36 V (2 x 18 V) |
| Bevel Angle Range | 47° - 0 - 46° |
| Blade Diameter | 216 mm |
| Blade RPM | 1,300 - 3,500 rpm |
| Bore Size | 30 mm |
| Dust Collection | Dust Bag Supplied |
| Dust Extraction | 27 mm / 36 mm Outlet |
| EAN Barcode | 4014549382240 |
| Electric Brake | Standard Feature |
| Manufacturer Part Number | 576847 |
| Max Bevel Cut @ 45º W x H | 305 mm x 40 mm |
| Max Compound Cut @ 45º W x H | 215 mm x 40 mm |
| Max Crosscut @ 0º W x H | 305 mm x 60 mm |
| Max Mitre Cut @ 45º W x H | 215 mm x 60 mm |
| Mitre Angle Range | 60° - 0 - 60° |
| Model | KSC 60 EB- Basic |
| Nett Weight | 18 kg |
| Overall L x W x H | 639 mm x 459 mm x 442 mm |
| Sound Power Level LwA [Uncertainty K] | 100 dB(A) [1.5 dB] |
| Sound Pressure Level LpA [Uncertainty K] | 91 dB(A) [1.5 dB] |
| Spindle Lock | Standard Feature |
| Vibration Cutting Wood [Uncertainty K] | 2.5 m/s² [3.0 m/s²] |
- Standard Delivery* - Free
