Festool Rubin 2 Sanding Discs 150mm (48 Hole)
- High-performance aluminium oxide abrasive for wood
- Final sanding for varnishing, preparatory sanding for oiling or waxing
- 48-hole Multi-Jetstream2 pad with Stickfix system
- Enhanced extraction when used with and extractor
- Helps achieve consistent smooth surface finish
- 150mm diameter
- Supplied in packs of 10
The 48-hole pattern of these Festool abrasive discs, when used with the matching Jetstream 2 pad and an extractor, results in virtually 100% dust extraction. The design even picks up dust attempting to escape from around the edge of the disc. The 48-hole design is fully compatible with the older 16-hole configuration.
Rubin 2 is a high quality aluminium oxide abrasive designed for use on bare wood and wooden products. It is ideal for sanding prior to painting, oiling or finishing furniture. Rubin 2 offers a faster finish; it quickly sheds wood fibres eliminating clogging so the abrasive stays sharp, leading to a greatly increased removal rate. Rubin 2 saves you money, the abrasive lasts longer and achieves consistent, high quality results in the least amount of time.
| Abrasive Backing | Paper and Hook and loop |
| Abrasive Disc Diameter | 150 mm |
| Abrasive Material | Aluminium Oxide |
| Abrasive Type | Rubin 2 |
| Model | STF D150/48 P60 RU2/10 |
Please note, respiratory items cannot be accepted for a refund once the seal is broken and the item has been worn.
