Festool Wood Scoring Blade for TSV60 Plunge Saw
- Specialist tool designed for use with coated or veneered chipboard
- Diamond scoring saw blade scores the top layer of the material
- Two diamond teeth enable splinter-free cuts on both sides
- Conical tooth shape allows for easy adjustment of the scoring width
- Extremely long service life
Your specialist tool for perfect, splinter-free cuts. The diamond scoring saw blade scores the top layer of the material, ensuring a splinter-free cut on both sides. Designed specifically for use with coated or veneered chipboard, the two diamond teeth enable splinter-free cuts, even in hard-to-machine materials.
Extremely long service life thanks to the use of diamond cutting teeth. The conical tooth shape makes it easy to adjust the scoring width to the saw cut.
Diameter 47mm, cutting width 1,95 - 2,5 mm, hole dia. 6.35 mm, teeth 2
| EAN Barcode | 4014549433065 |
- Standard Delivery* - Free
Please note, respiratory items cannot be accepted for a refund once the seal is broken and the item has been worn.
