Fuji Spray T75G T-Model Gravity Spray Gun
Spread the cost of orders up to £30,000 with iwocaPay.
We accept iwocaPay to give business customers more control when it comes to paying. iwocaPay is available for UK Limited Businesses and LLPs on orders of £150 to £30,000.
When you get to the iwocaPay checkout you'll see two choices:
- Pay Now in just a few clicks, you can scan a code to pay us straight from your bank account.
- Pay Later you'll be able to set up a payment plan with iwocaPay to split the cost with Pay in 3 (Interest Free) or Pay in 12 (3.33% Interest Rate Per 30 Days) equal monthly payments.
- Non-bleed design, air only passes through when trigger is pulled
- Side mounted spray pattern control knob allows continuous adjustment
- Centre mounted 600cc nylon gravity cup; stay-cool nylon handle
- Stainless steel fluid passages and external needle packing adjustment
- Metal fluid knob and collar, stainless steel internal components
- Rear rotating nipple for pressure tubes, easier use for the left-handed
3M Fuji Spray PPS 2.0 Large Lid & Collar - (Pkt 25)Special Price £48.29 £40.24 was £68.98 £57.48 Save £20.69 £17.24 -
The Fuji Spray T-Series Spray Gun features an exclusive side-mounted pattern control knob to adjust the size of the fan. This knob allows you to switch from a small to large pattern, or anywhere in between. Unlike HVLP turbine spray guns with the front collar adjustment, the pattern control knob offers full incremental fan size throughout the whole range. The fan pattern is adjustable from 25mm to 380mm from a distance of 200mm. Smaller than 25mm is achieved by moving closer to the object to be sprayed. All T-Series Spray Guns are installed with a 1.3mm needle and nozzle set-up. You can obtain a professional finish with all known coatings. The gun body is CNC machined to aircraft tolerances. All Fuji spray guns are non-bleed. Air passes through the spray gun only when the trigger is pulled. The light weight of the T-Series and easy-pull trigger means less fatigue for the operator. The T-75 Gravity Gun is assembled with a 600cc Nylon Cup, which provides a perfect seal, with no gasket required.
It is essential equipment is cleaned after every job and operating instructions are followed. Failure to do so will void warranty
Fuji Spray 2 Year Warranty
Fuji Spray® provides a 2 Year limited manufacturer's warranty to the original purchaser from the date of purchase against defects in materials and workmanship.
The warranty does not cover damage or defects caused by misuse, abuse, accidents, negligence, corrosion, normal wear and tear, inadequate maintenance, improper installation, incorrect operation, or unauthorised modifications or repairs.
All warranty claims are handled directly by Fuji Spray. Proof of purchase is required.
For warranty issues outside the UK: Please refer to the warranty procedures applicable in your country. If a product needs to be returned to the UK, all shipping and postage costs must be arranged and paid for by the customer.
Full warranty details, exclusions and claim procedures can be found on the Fuji Spray warranty website. N.B: This warranty is provided by Fuji Spray and is subject to the manufacturer's full terms and conditions.
| Cup Capacity | 600 cc |
| EAN Barcode | 612850051752 |
| Model | T Series |
| Suitable Adaptor for 3MPPS System | S2 and H/O Cup Required |
- Standard Delivery* - Free
