Drum Sanders: The secret to flawless finishes
What is a Drum Sander?
A drum sander is a workshop machine designed to sand large, flat surfaces with exceptional accuracy. It uses a rotating drum wrapped in abrasive material to remove fine layers of wood as the workpiece is fed through on a conveyor belt. Unlike handheld sanders, a drum sander offers consistent pressure, even sanding, and repeatable results.
Axminster Professional AP460DS Drum Sander
A heavy-duty, fixed head drum sander designed for stability and accuracy, with an open-ended design that lets you sand up to 920 mm wide panels (via double pass). A self cooling aluminium drum, cast iron bed, height adjustment and quiet variable-speed feed ensure controlled, high-quality finishes.
Axminster Professional AP406DS Drum Sander
This open-sided finishing sander is perfect for square frames and boards, featuring a sturdy floor stand, a rubber conveyor belt for a pristine finish, variable speed control, and tool-free belt changes for maximum convenience.
Laguna 16-32 Drum Sander 230V
A compact yet powerful sander with an open-ended drum for up to 810mm sanding width in two passes, digital readout for accuracy, patented quick adjust lever, and INTELLISAND technology for a flawless, consistent finish on a variety of wood types.
Axminster Professional AP640DS Drum Sander
Designed for workshops that demand speed and accuracy, this dual-drum system features a robust cabinet stand, powerful 3kW motor, precise digital controls and more to deliver exceptional results. Run fine and coarse grits simultaneously across a wide range of materials including wood, plastics and similar.
Axminster Professional AP940DDS Drum Sander
A high-capacity, dual-drum sander built for industrial use, capable of handling very wide workpieces and delivering a fine finish in a single pass—ideal for professional workshops with high throughput needs.
Why woodworkers need one
Hand sanding or using a belt sander can be time-consuming, inconsistent, and physically demanding—especially on large panels or glued-up boards. A drum sander eliminates these issues by delivering:
  • Consistent thickness and finish across the entire surface
  • Time savings on large or repetitive sanding tasks
  • Reduced fatigue and improved workshop efficiency
  • Cleaner results with less risk of gouging or uneven sanding
It’s particularly useful for:
  • Wide tabletops and cabinet panels
  • Drawer sides and face frames
  • Veneers and thin stock
  • End grain cutting boards
  • Pre-sanding before finishing or glue-up
What you might use instead (and why it falls short)
Before investing in a drum sander, many woodworkers rely on:
  • Hand planes – great for skilled users, but slow and prone to tear-out on tricky grain
  • Belt sanders – fast but hard to control over large areas
  • Planer/thicknessers – ideal for dimensioning, but not for final surface prep or sanding glued panels
A drum sander bridges the gap between rough dimensioning and fine finishing. It’s not a replacement for a planer, but rather a complement—especially when working with figured grain, end grain, or delicate veneers that could chip or tear in a planer.
What you can do with a drum sander
  • Flatten glued-up panels after glue-up to remove squeeze-out and level joints
  • Sand figured or difficult grain without tear-out
  • Smooth end grain on cutting boards or butcher blocks
  • Refine thick veneers cut on a bandsaw
  • Pre-sand components before assembly for a cleaner finish
The Axminster Professional AP406DS Drum Sander even supports light metal sanding and brush sanding with optional accessories.
Drum Sanders - AP406DS
Why it’s a smart investment
Drum sanders pay for themselves in time saved, quality improved, and frustration avoided. Here’s why they’re worth it:
  • Precision: Achieve uniform thickness and finish across wide surfaces
  • Versatility: Sand wood, veneers, and even light metals
  • Durability: Machines like the AP460DS are built with cast iron tables and heavy-duty motors for long-term reliability
  • Productivity: Speed up your workflow and reduce manual labour
  • Professional results: Elevate the quality of your finished pieces
Final thoughts
If you’re serious about woodworking, a drum sander is more than a luxury—it’s a game-changer. It takes the guesswork out of sanding, delivers flawless finishes, and helps you work smarter, not harder.
Ready to upgrade your sanding game? Explore our full range of drum sanders or check out our buying guide to find the perfect fit for your workshop.
Discover more...
If you've enjoyed reading this guide, why not take a look at some of our blogs.
Get in touch!
Send us a photograph and tell us all about what you've recently purchased or what you've been making. Alternatively, get in touch via our social media platforms. Find us on Facebook or Instagram.
