When should you replace your Easy Wood Tools Carbide Cutters?
Woodturners love Easy Wood Tools for one simple reason: they take the hassle out of sharpening. Instead of grinding and honing traditional turning tools, Easy Wood Tools use replaceable carbide cutters that stay sharp for longer and can be quickly rotated or replaced when needed.
But how do you know when it's time for a new cutter? And what signs should you look for before performance starts to suffer?
Why Carbide Cutters are so popular
Easy Wood Tools revolutionised woodturning by introducing carbide-tipped turning tools that make achieving a clean finish much easier, even for beginners. The cutters feature a precision-ground edge that delivers smooth, controlled cuts on a wide range of timbers.
Unlike conventional High Speed Steel tools, there's no sharpening equipment required. Once the edge becomes worn, simply rotate the cutter to a fresh edge or replace it entirely.
This convenience is one of the reasons replacement Easy Wood Tools carbide cutters are among the best-selling accessories in the range.
Easy Wood Hollowers
Signs your Carbide Cutter needs replacing
Carbide cutters are incredibly durable, but they don't last forever. As the edge wears, you'll usually notice a few tell-tale signs.
Rougher surface finish
If your turning projects suddenly require more sanding than usual, a worn cutter may be the culprit. A sharp carbide edge should leave a clean, consistent finish directly off the tool.
Increased tear-out
Dull cutters can struggle to slice cleanly through wood fibres, particularly on figured timbers and end grain. This often results in tear-out and a less refined finish.
More pressure required
One of the biggest indicators of wear is needing to push harder during a cut. Sharp carbide cutters should cut effortlessly with minimal force.
Burning or excessive heat
A worn cutting edge can generate friction rather than making a clean cut. This may cause heat build-up or burn marks on the workpiece.
Visible damage
Inspect your cutter regularly. Chips, dents, cracks or rounded cutting edges are clear signs that it's time to rotate or replace the cutter.
Top Tip! Rotate first. Replace later.
Many Easy Wood Tools cutters feature multiple usable cutting edges
Before fitting a replacement, loosen the retaining screw and rotate the cutter to expose a fresh edge. Once all cutting edges have been used, it's time for a new cutter. This simple design helps maximise cutter life and keeps running costs low.
Easy Wood Tools Full Size range
Which Easy Wood Tools Cutter do I need?
Easy Wood Tools use several cutter profiles, each designed for different turning applications:
Round Cutters
Ideal for hollowing and making smooth, flowing cuts inside bowls and vessels.
Square Cutters
Commonly used for general-purpose turning, roughing and finishing spindle work.
Diamond Cutters
Perfect for creating fine details, tight corners and intricate decorative work.
Negative Rake Cutters
Designed for finishing cuts and challenging materials such as resin, acrylics and highly figured timber.
Beading Cutters
Specially designed for cutting decorative beads and repeated profiles with speed and consistency.
Parting Cutters
Used for clean parting cuts, sizing spigots and defining shoulders.
When ordering replacements, always check the cutter type fitted to your tool to ensure compatibility.
How long do Carbide Cutters last?
There is no fixed lifespan because cutter life depends on:
  • Wood species being turned
  • Presence of bark, dirt or inclusions
  • Turning speed
  • Frequency of use
  • Amount of material removed
Turning clean, kiln-dried timber will generally result in significantly longer cutter life than working with reclaimed or abrasive materials.
For many hobby woodturners, a cutter can last months of regular use before needing replacement.
Keep spare cutters in the workshop
There's nothing worse than being halfway through a project and discovering your cutter has reached the end of its life.
Keeping spare Easy Wood Tools carbide cutters on hand means you can quickly swap out a worn edge and get straight back to turning.
Whether you're roughing bowl blanks, creating delicate finials or hollowing vessels, sharp cutters help produce cleaner results with less effort and less sanding.
Easy Wood Tools Mid Size Range
Find genuine Easy Wood Tools replacement Cutters
At Axminster Tools, we stock a wide range of genuine Easy Wood Tools replacement carbide cutters to keep your turning tools performing at their best.
Whether you need round, square, or diamond cutters, you'll find the right replacement for your Easy Wood Tools turning system.
A selection from the range
Easy Wood Tools Ci5 Carbide Cutter - Round
(5)
From £16.78 £13.98
Easy Wood Tools Ci2-SQ Carbide Cutter Square
(3)
From £15.88 £13.23
Easy Wood Tools Ci4 Carbide Cutter - Diamond
(3)
From £19.58 £16.32
Easy Wood Tools Ci6-R1-NR Carbide Cutter 1" Negative Rake
(1)
From £20.88 £17.40
Easy Wood Tools 3/8" Negative Rake Beading Cutter
(3)
From £32.38 £26.98
Shop now
Browse our full range of Easy Wood Tools replacement cutters and keep your tools cutting cleanly project after project.
Choose your cutters
