Laguna F1 Fusion Table Saw 230V
- Accurate Cuts: Smooth ground table and twin mitre fence slots ensure precise cuts
- Additional workspace: right, left, and rear extension tables for larger projects
- Flexibility and precision: fully adjustable T-style rip fence with hi-low sub fence
- Powerful performance: 1.45 kW induction motor delivers robust performance
- Ease of use: smooth tilt and height adjustment allows effortless customisation
- Surface smoothness: close clearance phenolic table insert with levelling adjusters
- Safe and efficient: transparent clear crown guard with waste clearance
Precision in every cut
High performing reliable machines designed for sustained stability and power.
Powerful accuracy
760mm rip capacity with powerful 1.45kW induction motor
Smooth ground tabletop
Durable, low-friction surface for quality cuts and long-term use
Twin mitre fence slots
Accurate and consistent angled cuts to left and right of the blade
Right, left and rear extension tables
For greater wood handling
Fully adjustable T style rip fence
Enables quick and accurate settings with a solid quick lock
Zero clearance throat plate
With fine adjustment screws for precise alignment with the table surface
Tool-free spindle lock and a riving knife
For fast blade changes
Transparent crown guard
Enhances visibility and waste clearance during operation
Axminster Tools Extended 2-Year Warranty
Choose Axminster Tools' extended warranty and enjoy the confidence of knowing your Laguna machine is backed by exceptional service and care.
Find out moreUnlock the full potential of your machine
With the extensive range of Laguna accessories
See the accessoriesRecommended Accessories
Axminster Clear Lightweight PVC Extraction Hose - 100mm x 2.5mSpecial Price £35.88 £29.90 was £51.28 £42.73 Save £15.40 £12.83 -
Laguna C|Flux 1 Cyclone Extractor 230VSpecial Price £1,349.98 £1,124.98 was £1,499.98 £1,249.98 Save £150.00 £125.00 -
Laguna Fusion Zero Clearance Throat PlateFrom £49.98 £41.65 -
Laguna Fusion 1 Table Saw Fixed Wheel AssemblyFrom £34.98 £29.15 -
Laguna Riving Knife For F1 & F3 Table SawsFrom £32.95 £27.46
The Laguna F1 Fusion Table Saw is a high-quality, reliable machine that consistently delivers stability and power, ensuring excellent performance and dependability with every use.
The F1 Fusion features a large precision ground mirror-finished cast iron tabletop, complemented by additional steel fabricated tables on the left and right, providing an overall table width of 112cm. An MDF rear extension table increases the table depth to 130cm, adding further stability when ripping long lengths. The fully adjustable T-style rip fence with a hi-low sub fence provides flexibility and precision, while the hi-low read out ensures easy and accurate measurements. Powered by a 1.45 kW induction motor, this table saw delivers robust and reliable performance, making it a dependable tool in your workshop.
The F1 takes a 250mm saw blade and provides a maximum cutting depth of 79mm at 90 degrees, enabling deep, precise cuts through thick materials. This is ideal for robust woodworking projects like cutting large panels or thick hardwoods. Additionally, the impressive rip capacity of 760mm allows you to handle wide panels and large sheets of material with ease, providing flexibility and ensuring long, straight cuts with precision and confidence. The hi-low fence adjustment offers versatile cutting options, and the crown guard ensures safety during deep cuts.
Convenience is key with the onboard tool storage, keeping your tools organised and within reach. The all-metal spindle block facilitates quick blade changes, saving you time and effort. The strategically positioned on-off control box allows for effortless access and operation, while the deep rip cut and wide panel crosscut capabilities make handling a variety of cutting tasks easy. The adjustable table tilt and height allow for customised cutting angles with the positive adjusting hand wheels. Dual port extraction ensures efficient dust collection that extracts from above and below the table and has a 100mm take off point, keeping your workspace clean and safe.
One of the standout features of the Laguna F1 Fusion Table Saw are the two smooth blade adjustments hand wheels for the rise and fall and the tilt. The tilt on the blade angle can be easily read off of the large scale on the front of the cabinet. The close clearance phenolic table insert with levelling adjusters ensures a smooth and even surface, enhancing the quality of your cuts. Safety and efficiency are prioritised with the transparent clear crown guard, specially designed for waste clearance.
Investing in the Laguna F1 Fusion Table Saw means equipping your workshop with a tool that combines precision, versatility, and reliability, making it the perfect choice for both entry-level woodworkers and seasoned DIY enthusiasts.
Supplied with; on-board storage points for all the accessories, mitre fence that is hyper accurate when travelling in the T slots, 40 tooth TCT sawblade and quick release riving knife for fast blade changes.
Axminster Tools offers an optional 2-year extended warranty on all Laguna machines, ensuring peace of mind and comprehensive coverage. This extended warranty must be purchased at the same time as your Laguna machine. Please see the warranty link below for more details.
Laguna 1-Year Warranty
The standard 1-year manufacturer's warranty for Laguna machines guarantees satisfactory quality, fitness for purpose, freedom from material defects, and compliance with UK regulations.
Enhance your peace of mind with Axminster Tools' optional 2-year extended warranty on all Laguna machines. This extended warranty, is only available for purchase at the time of purchasing your Laguna machine. It ensures comprehensive coverage for any defects in workmanship, parts, and materials for a full two years from the original invoice date. With this extended warranty, you can rest assured that any faulty part will be repaired or replaced at no cost to you, providing you with the highest level of support and protection on your investment.
Choose Axminster Tools' extended warranty and enjoy the confidence of knowing your Laguna machine is backed by exceptional service and care. Find out more
| Blade Diameter | 250 mm |
| Blade RPM | 3,800 rpm |
| Blade Tilt | -3° to 45° |
| Bore Size | 30 mm |
| Dust Extraction Outlet | 100 mm |
| Max Depth of Cut @ 45º | 56 mm |
| Max Depth of Cut @ 90º | 79 mm |
| Max Width of Cut with Fence | 760 mm |
| Min Extraction Airflow Required | 934 m³/hr (550 cfm) |
| Model | F1 Fusion |
| Nett Weight | 110 kg |
| Overall L x W x H | 1,550 x 1,405 x 1,100 mm |
| Plug Fitted | UK 16A Plug |
| Power | 1.45 Kw |
| Rating | Home Workshop |
| Riving Knife Thickness | 2.4 mm |
| T Slot Size | 19 mm & 23 mm |
| Table Height | 887 mm |
| Voltage | 230 V |
